spark plugs
Old Jun 27, 2010 | 09:06 AM
lockadam2112's Avatar
spark plugs
Can anyone list the the spark plug part numbers and the heat range why would you go with a hotter or colder plug and the gap numbers thanks.
Old Jun 27, 2010 | 09:09 AM
bluebanana23's Avatar
Pay a visit to sparkplugs.com and read up. They have everything you want there. Go 1 step colder for every hundred hp you increase by.
Old Jul 17, 2010 | 08:01 AM
Yota Eater's Avatar
Veteran: Air Force
Thumbs up
I like item no: 3994 from sparkplugs.
NGK BP8ES. no resistor so may interfere w/stereo, etc. I have no stereo -RS.
Old Jul 17, 2010 | 08:27 AM
SpoolinUp's Avatar
Silver Sponsor
For an Evo 8 BR7ES/BR8ES are the proper plugs. Some use BPR7ES/BPR8ES.
IW22/IW24 are the iridiums you'd want. For mild mods 7 or IW22 heat range. A bit wilder and you'd want a 8 or IW24 heat range. .026 is a safe gap to start with.
If you plan to get tuned, ask the tuner what he recommends.
__________________
-Matt- http://www.SpoolinUp.com
"Performance without the Price Tag"
Old Jul 18, 2010 | 01:20 PM
ta ace's Avatar
search search
Old Jul 18, 2010 | 01:38 PM
justinschmidt's Avatar
Stock setups go with bpr6es, 7's and 8's from there, stock gap should be fine.
You really shouldn't need anything colder for quite a while.
Old Jul 18, 2010 | 01:39 PM
BriK's Avatar
Just stick with stock-- stock part number and heat range. Stock plugs are in cars with 500whp+.
Old Jul 18, 2010 | 01:49 PM
ta ace's Avatar
what is stock gap?
Old Jul 19, 2010 | 01:18 AM
Agreed x2
Old Jul 19, 2010 | 01:27 AM
EvolutinIX's Avatar
Stock, they come pre gapped.
Old Jul 19, 2010 | 01:33 AM
jason05evoviii's Avatar
Agreed as well.
X3
Old Jul 19, 2010 | 03:58 PM
SmurfZilla's Avatar
On E85 on both sotck turb oand BBK full I had to Denso IKH22 (1 step colder) because I kept breaking up under high boost/high rpm. Before i go black the ignition system is getting upgraded.
Old Jul 20, 2010 | 12:19 AM
You should be using ngk's!
babaz7
Feb 3, 2016 08:48 PM
franc01
May 14, 2015 05:25 AM
Silver09RA
20
May 8, 2014 03:28 PM
lousEVOxmr
Dec 25, 2009 08:07 AM
alsworld
23
Jul 14, 2007 02:37 PM
