Recommended injectors for set up?
Old Jul 5, 2010 | 11:37 AM
EvoJoeIX's Avatar
that is true, but if your making all kinds of upgrades, injectors would usually be the last piece to the puzzle considering you need to be tuned ASAP for them or your car will run so horrible. so for someone to put in 1000cc injectors then keep upgrading, is pointless
Old Jul 5, 2010 | 07:31 PM
grey~ghost's Avatar
my tuner said to not go over 850cc for my build, that anything over would be overkill for the ECU. im kind of confused at this point because i see people running 1000cc for similar builds.
Old Jul 5, 2010 | 09:46 PM
white_evo27's Avatar
im gonna be running 1200cc on a similar setup, but NO meth
Old Jul 6, 2010 | 12:58 PM
EvoJoeIX's Avatar
with meth you can get away with running a smaller injector then you would for straight pump gas.
Old Jul 6, 2010 | 01:01 PM
awdturbo8's Avatar
Stockers for sure
Old Jul 7, 2010 | 12:15 AM
es850revo's Avatar
Ive seen many guys runing 1000ccs on stock ecu , used to myself no problems at all! now im running an .............Hydra
Old Jul 11, 2010 | 10:33 AM
420a-t's Avatar
Stockers are fine. If you ever upgrade turbos, the two biggest things to determine what size of injector you'll need is airflow and fuel pressure. I have a little chart somewhere that has what injector size can keep up with how many lbs/min at 43.5psi base fuel pressure if someone wants to see it.
Old Jul 11, 2010 | 11:14 AM
420a-t's Avatar
I found it. Here you go (posted by spyderturbo007):
E85 fuel:
Originally Posted by DarkHorse
390cc @ 100% IDC will support 21.80 lbs/min. Global Correction: +50.00%
390cc @ 80% IDC will support 17.44 lbs/min
450cc @ 100% IDC will support 25.15 lbs/min. Global Correction: +30.00%
450cc @ 80% IDC will support 20.12 lbs/min
550cc @ 100% IDC will support 30.74 lbs/min. Global Correction: +6.36%
550cc @ 80% IDC will support 24.59 lbs/min
580cc @ 100% IDC will support 32.42 lbs/min. Global Correction: +0.86%
580cc @ 80% IDC will support 25.94 lbs/min
650cc @ 100% IDC will support 36.33 lbs/min. Global Correction: -10.00%
650cc @ 80% IDC will support 29.07 lbs/min
660cc @ 100% IDC will support 36.89 lbs/min. Global Correction: -11.36%
660cc @ 80% IDC will support 29.51 lbs/min
680cc @ 100% IDC will support 38.01 lbs/min. Global Correction: -13.97%
680cc @ 80% IDC will support 30.41 lbs/min
720cc @ 100% IDC will support 40.24 lbs/min. Global Correction: -18.75%
720cc @ 80% IDC will support 32.20 lbs/min
750cc @ 100% IDC will support 41.92 lbs/min. Global Correction: -22.00%
750cc @ 80% IDC will support 33.54 lbs/min
780cc @ 100% IDC will support 43.60 lbs/min. Global Correction: -25.00%
780cc @ 80% IDC will support 34.88 lbs/min
850cc @ 100% IDC will support 47.51 lbs/min. Global Correction: -31.18%
850cc @ 80% IDC will support 38.01 lbs/min
880cc @ 100% IDC will support 49.19 lbs/min. Global Correction: -33.52%
880cc @ 80% IDC will support 39.35 lbs/min
950cc @ 100% IDC will support 53.10 lbs/min. Global Correction: -38..42%
950cc @ 80% IDC will support 42.48 lbs/min
1000cc @ 100% IDC will support 55.89 lbs/min. Global Correction: -41.50%
1000cc @ 80% IDC will support 44.72 lbs/min
1150cc @ 100% IDC will support 64.28 lbs/min. Global Correction: -49.13%
1150cc @ 80% IDC will support 51.42 lbs/min
1200cc @ 100% IDC will support 67.07 lbs/min. Global Correction: -51.25%
1200cc @ 80% IDC will support 53.66 lbs/min
1600cc @ 100% IDC will support 89.43 lbs/min. Global Correction: -63.44%
1600cc @ 80% IDC will support 71.55 lbs/min
1850cc @ 100% IDC will support 103.41 lbs/min. Global Correction: -68.38%
1850cc @ 80% IDC will support 82.72 lbs/min"
And gas:
Injectors
390cc @ 100% IDC will support 27.99lbs/min
390cc @ 80% IDC will support 22.39lbs/min
450cc @ 100% IDC will support 32.30lbs/min
450cc @ 80% IDC will support 25.84lbs/min
550cc @ 100% IDC will support 39.48lbs/min
550cc @ 80% IDC will support 31.58lbs/min
580cc @ 100% IDC will support 41.63lbs/min
580cc @ 80% IDC will support 33.31lbs/min
650cc @ 100% IDC will support 46.66lbs/min
650cc @ 80% IDC will support 37.32lbs/min
660cc @ 100% IDC will support 47.37lbs/min
660cc @ 80% IDC will support 37.90lbs/min
720cc @ 100% IDC will support 51.68lbs/min
720cc @ 80% IDC will support 41.34lbs/min
750cc @ 100% IDC will support 53.83lbs/min
750cc @ 80% IDC will support 43.07lbs/min
780cc @ 100% IDC will support 55.99lbs/min
780cc @ 80% IDC will support 44.79lbs/min
850cc @ 100% IDC will support 61.01lbs/min
850cc @ 80% IDC will support 48.80lbs/min
880cc @ 100% IDC will support 63.17lbs/min
880cc @ 80% IDC will support 50.53lbs/min
950cc @ 100% IDC will support 68.19lbs/min
950cc @ 80% IDC will support 54.55lbs/min
1000cc @ 100% IDC will support 71.78lbs/min
1000cc @ 80% IDC will support 57.42lbs/min
1150cc @ 100% IDC will support 82.54lbs/min
1150cc @ 80% IDC will support 66.04lbs/min
1600cc @ 100% IDC will support 114.85lbs/min
1600cc @ 80% IDC will support 91.88lbs/min
Fuel pumps
Numbers will be arranged in the following format:
"X psi = Y lbs/min"
where X = Boost and Y = Max airflow supported by pump
Walboro 190lph
10psi = 46.48lbs/min
11psi = 45.89lbs/min
12psi = 45.26lbs/min
13psi = 44.58lbs/min
14psi = 43.86lbs/min
15psi = 43.09lbs/min
16psi = 42.28lbs/min
17psi = 41.43lbs/min
18psi = 40.54lbs/min
19psi = 39.60lbs/min
20psi = 38.62lbs/min
21psi = 37.60lbs/min
22psi = 36.53lbs/min
23psi = 35.42lbs/min
24psi = 34.26lbs/min
25psi = 33.06lbs/min
Walboro 190lph (Rewired)
10psi = 60.68lbs/min
11psi = 59.85lbs/min
12psi = 59.01lbs/min
13psi = 58.16lbs/min
14psi = 57.29lbs/min
15psi = 56.40lbs/min
16psi = 55.49lbs/min
17psi = 54.57lbs/min
18psi = 53.63lbs/min
19psi = 52.67lbs/min
20psi = 51.70lbs/min
21psi = 50.71lbs/min
22psi = 49.71lbs/min
23psi = 48.68lbs/min
24psi = 47.64lbs/min
25psi = 46.58lbs/min
Walboro 255lph
10psi = 63.53lbs/min
11psi = 62.88lbs/min
12psi = 62.20lbs/min
13psi = 61.48lbs/min
14psi = 60.72lbs/min
15psi = 59.93lbs/min
16psi = 59.10lbs/min
17psi = 58.23lbs/min
18psi = 57.33lbs/min
19psi = 56.39lbs/min
20psi = 55.41lbs/min
21psi = 54.39lbs/min
22psi = 53.34lbs/min
23psi = 52.26lbs/min
24psi = 51.13lbs/min
25psi = 49.97lbs/min
Walboro 255lph (Rewired)
10psi = 72.15lbs/min
11psi = 71.47lbs/min
12psi = 70.77lbs/min
13psi = 70.04lbs/min
14psi = 69.29lbs/min
15psi = 68.52lbs/min
16psi = 67.73lbs/min
17psi = 66.92lbs/min
18psi = 66.08lbs/min
19psi = 65.22lbs/min
20psi = 64.34lbs/min
21psi = 63.43lbs/min
22psi = 62.50lbs/min
23psi = 61.55lbs/min
24psi = 60.58lbs/min
25psi = 59.58lbs/min
Walboro 255lph HP
10psi = 64.64lbs/min
11psi = 64.19lbs/min
12psi = 63.74lbs/min
13psi = 63.30lbs/min
14psi = 62.86lbs/min
15psi = 62.42lbs/min
16psi = 61.99lbs/min
17psi = 61.56lbs/min
18psi = 61.13lbs/min
19psi = 60.71lbs/min
20psi = 60.29lbs/min
21psi = 59.87lbs/min
22psi = 59.46lbs/min
23psi = 59.05lbs/min
24psi = 58.64lbs/min
25psi = 58.24lbs/min
Walboro 255lph HP (Rewired)
10psi = 74.29lbs/min
11psi = 73.86lbs/min
12psi = 73.43lbs/min
13psi = 73.01lbs/min
14psi = 72.58lbs/min
15psi = 72.15lbs/min
16psi = 71.72lbs/min
17psi = 71.28lbs/min
18psi = 70.85lbs/min
19psi = 70.42lbs/min
20psi = 69.99lbs/min
21psi = 69.55lbs/min
22psi = 69.12lbs/min
23psi = 68.68lbs/min
24psi = 68.24lbs/min
25psi = 67.80lbs/min
Denso US EVO 8 Stock Pump
10psi = 39.96lbs/min
11psi = 39.10lbs/min
12psi = 38.12lbs/min
13psi = 37.31lbs/min
14psi = 36.39lbs/min
15psi = 35.45lbs/min
16psi = 34.48lbs/min
17psi = 33.49lbs/min
18psi = 32.49lbs/min
19psi = 31.47lbs/min
20psi = 31.47lbs/min
21psi = 29.35lbs/min
22psi = 28.26lbs/min
23psi = 27.15lbs/min
24psi = 26.02lbs/min
25psi = 24.87lbs/min
Denso EVO 8 Stock Pump (Rewired)
10psi = 51.23lbs/min
11psi = 50.36lbs/min
12psi = 49.48lbs/min
13psi = 48.60lbs/min
14psi = 47.72lbs/min
15psi = 46.85lbs/min
16psi = 45.97lbs/min
17psi = 45.09lbs/min
18psi = 44.20lbs/min
19psi = 43.32lbs/min
20psi = 43.32lbs/min
21psi = 41.55lbs/min
22psi = 40.67lbs/min
23psi = 39.78lbs/min
24psi = 38.90lbs/min
25psi = 38.01lbs/min
Denso Supra 260
10psi = 70.70lbs/min
11psi = 70.06lbs/min
12psi = 69.42lbs/min
13psi = 68.77lbs/min
14psi = 68.12lbs/min
15psi = 67.45lbs/min
16psi = 66.78lbs/min
17psi = 66.10lbs/min
18psi = 65.42lbs/min
19psi = 64.73lbs/min
20psi = 64.03lbs/min
21psi = 63.32lbs/min
22psi = 62.60lbs/min
23psi = 61.88lbs/min
24psi = 61.15lbs/min
25psi = 60.41lbs/min
Denso Supra 260 (Rewired)
10psi = 82.91lbs/min
11psi = 82.38lbs/min
12psi = 81.83lbs/min
13psi = 81.28lbs/min
14psi = 80.73lbs/min
15psi = 80.17lbs/min
16psi = 79.60lbs/min
17psi = 79.03lbs/min
18psi = 78.46lbs/min
19psi = 77.88lbs/min
20psi = 77.08lbs/min
21psi = 76.71lbs/min
22psi = 76.11lbs/min
23psi = 75.51lbs/min
24psi = 74.91lbs/min
25psi = 74.30lbs/min
GSXPimp
Apr 12, 2016 06:10 AM
boostedadiction
Feb 9, 2015 05:01 AM
Rocket
Jun 7, 2013 01:59 PM
Evo8g23
Jul 31, 2011 11:53 AM
LT1runner
Automotosports - Illinois
66
Aug 5, 2007 08:36 AM
