Best oil catch can/breather set up
Old Jul 30, 2011 | 04:37 PM
Evo8g23's Avatar
I am getting some blow by due to crank case pressure and need a catch can/breather set up...Any suggestion on best set up???
Old Jul 30, 2011 | 04:44 PM
fcapistran's Avatar
I am selling my buschur catch can.It's recirculating so you don't have to drain it. here's the link.lemme know if you are interested.
https://www.evolutionm.net/forums/sa...arts-sale.html
Old Jul 30, 2011 | 05:13 PM
blknblubkrdude's Avatar
I like the Saikou Michi setup. Dual can is the best way to do it. I am only running a can on the turbo inlet side to keep oil out of the turbo/IC.
Old Jul 30, 2011 | 05:33 PM
Evo8g23's Avatar
Good looks on the Saikou Michi set up look like some quality catch cans but i think i'm gonna go with the Buschur one...It seems like the right one and i like the recirculating feature...Thanks guys
Old Jul 30, 2011 | 06:24 PM
Just remember, if the can is vented to the atmosphere, that means metered air is escaping before it reaches the combustion chamber.
Old Jul 30, 2011 | 06:34 PM
mt057's Avatar
Isn't the intake pulling a slight vaccum? Wouldn't it pull in air?
Old Jul 30, 2011 | 06:52 PM
420a-t's Avatar
I think you mean extra air is coming into the combustion chamber that isn't measured...
Old Jul 30, 2011 | 09:58 PM
Yup, but it also depends on the placement of it, and whether the car is in vacuum or boost.
Old Jul 30, 2011 | 10:11 PM
B.J.@ToxicFab's Avatar
A vented catch can will be a vacuum leak on a car with a maf....I personally run 2 sealed DC3 catch cans on my car running a "hacked" maf...Once I switched to SD I will run a vented catch can...
Old Jul 31, 2011 | 05:26 AM
Blue Evo 8's Avatar
I'm running a Buschur catch can set up and I like it very much.
Old Jul 31, 2011 | 11:29 AM
RockmanX's Avatar
I was running perrin oil catchcan did a good job its for sale now as its not included in my built setup
Old Jul 31, 2011 | 11:53 AM
detroit pistins's Avatar
Originally Posted by b.j.@toxicfab
a vented catch can will be a vacuum leak on a car with a maf....i personally run 2 sealed dc3 catch cans on my car running a "hacked" maf...once i switched to sd i will run a vented catch can...
+1
GSXPimp
Apr 12, 2016 06:10 AM
Evolution7GSR
Mar 24, 2015 07:25 AM
Randal
Aug 27, 2012 06:09 PM
vmrevo9
12
May 15, 2009 12:44 AM
fugiwara
47
Apr 13, 2008 05:54 AM
