Car isn't firing.
Old Jul 4, 2010 | 01:09 PM
PurEvo's Avatar
Car isn't firing.
I just had my motor built and running recently. I drove and put over 100 miles trying to break it in. While cruising on the interstate, my car suddenly started sounding weird. I put it in neutral to coast down but the car shut off. I've checked timing, which is good. Did a compression check, which is good and even across. Got fuel, got oil, got air. Checked all the couplers and vacuum lines, good. Everything seems good, except spark. Seems like 1 and 4 is sparking, but 2 and 3 isn't sparking. I've changed spark plugs, and coils, but same thing. 1 and 4 still spark, 2 and 3 still no spark. Anybody have any idea's??
Old Jul 4, 2010 | 05:04 PM
jy951's Avatar
Is your check engine light on? Can you get a scan tool and read the engine codes?
Old Jul 4, 2010 | 05:35 PM
PurEvo's Avatar
There's no check engine light on. Oh, it's an Evo 9. I used a friends coils from his Evo 8 if that mattered.
Old Sep 6, 2010 | 05:17 PM
PurEvo's Avatar
Is there a way to check if the ecu it is going bad? People are thinking it's my ecu.
Old Sep 6, 2010 | 11:29 PM
white_evo27's Avatar
try different coils? im no expert but if it were me i wouldnt be using evo Vlll coils in a IX
SpoolinUP has a good COP system to use! im about to order one this week!
Old Sep 7, 2010 | 09:51 AM
OneEyedJack's Avatar
Exhaust cam sensor. This just happened to me. I had fuel all over, spark on 2, it would not fire over. Most times it would start a bit, but die pretty much immediately.
Everyone thought it was my ECU as well. Turned out the immobilizer had tripped, and after I fixed that with ECUflash and got fuel/spark back, realized I only had spark on 2 cyl. I tried swapping coil packs, I had an evo 9 and put an evo 8 coil pack in that I bought used, made no difference, still only spark on 2. Swapped exh cam sensor, car fired right up.
I'm still driving around with 1 evo 9 pack and 1 evo 8 pack...
Old Sep 7, 2010 | 04:21 PM
PurEvo's Avatar
I sure hope your right. Now, i need to find my evo friends and see if they can swing by to let me test.
Old Sep 9, 2010 | 11:58 AM
dmitirygolos's Avatar
good luck on that
Old Sep 10, 2010 | 04:19 PM
PurEvo's Avatar
changed out the exhaust cam sensor. But it didn't fix the problem. The motor is running smoother though. But still not firing on 2 and 3. Any more ideas?
Old Sep 10, 2010 | 09:55 PM
apexisilver8gsr's Avatar
most likely its your ECU man
Old Sep 13, 2010 | 06:18 PM
PurEvo's Avatar
I'm not good with electrical stuff but this is what I did. I cranked the car and let it idle. I used a test light and touched the ecu pin for ign coil 1 and 4. The motor sounded like it wanted to shut off. I touched the ecu pin for ign coil 2 and 3. Nothing happen. Does this confirms that the ecu is bad?
Old Sep 19, 2010 | 12:26 AM
PurEvo's Avatar
problem solved. Had a short in the wire harness. The wire went to the coil for 2 and 3. It's all covered and motor is running good again.
Ecu wasn't the problem.
Old Sep 19, 2010 | 12:43 AM
Drifting Away's Avatar
I would upgrade to a spark tech system, havent driven on mine yet but my tuner tells my my car is doing much better with it on .
Old Sep 19, 2010 | 05:01 PM
PurEvo's Avatar
I want to. But i spent a good bit on an AEM EMS already. lol
ezzey
Jul 19, 2016 04:48 PM
TRASHY_GTS
Toronto Lancer Club
Jan 27, 2012 02:37 PM
evo_soul
Toronto Lancer Club
13
Dec 3, 2011 08:39 AM
jirou
Lancer Engine Management / Tuning Forums
Sep 14, 2010 03:50 AM
EatSleepBoost
Mar 26, 2008 10:25 AM
