Schroth Harness Questions
Old Jul 11, 2010 | 08:07 AM
shaggy4267's Avatar
Already searched the Schroth harness threads...seen alot on installs.. no reviews.
Im looking at getting a pair of Schroth Rallye 4 harnesses. I could use some feedback from so owners. Any issues or concerns?
Also, If I'm only going to use the harness at the track, what do you do with it while on the street? Latch it and pull it tight to the seat behind you?
Thanks in advance.
Old Jul 11, 2010 | 08:09 AM
EvoDan2004's Avatar
i can help you in 2 weeks. im having the car fitted for a role bar and i got the clubman 5 point harness. they seem to be a very nice harness. everything they make is good quality.
Old Jul 11, 2010 | 08:42 AM
chu's Avatar
chu
I'm running these harness in my car now. The brackets bolts to the original location of the stock belts. However, the is one modification. The two bracket that are bolts to the rear seats must be bent to a 45 degree angle. It very easy to do. Other than that, its straight forward. I use the stock belts for dd, and the harness for autox. I fold them back when I'm not using them.
Old Jul 11, 2010 | 08:51 AM
shaggy4267's Avatar
Not worried about the install seems very simple.
chu, when you "fold them back", does that mean they are up against your back during street driving? Is it comfortable?
Old Jul 11, 2010 | 12:17 PM
chu's Avatar
chu
I throw the shoulder straps around the sides to the back side of the seat, as if they're not there at all!
Old Jul 11, 2010 | 12:29 PM
ChuckP's Avatar
You need a rollbar or cage to run a harness. Anything less and you are playing with your life.
Old Jul 11, 2010 | 05:33 PM
chu's Avatar
chu
Thats why you dont wear harnesses on the street!
Old Jul 11, 2010 | 05:40 PM
shaggy4267's Avatar
[quote=evodan2004;8480601]i can help you in 2 weeks. quote]
Help with feedback or a pair of harnesses?
Old Jul 12, 2010 | 06:25 AM
kelley nelson's Avatar
I had one in my Subie that I used just for autocrossing. It got a lot of use and held up well, but I did eventually break the 'knob' off one of the sticks that goes in the end of each belt. (The stick gives you something to pull on when tensioning the belt. I was co-driving my car with someone else, so we were adjusting the lap belt very often.
The harness really holds you tight in the seat and you'll be surprised how much more control of the car you can get, when you don't have to use your arms to help hold you in place.
Old Jul 12, 2010 | 06:40 AM
Peter Tiebout's Avatar
I have also been using the Schroth Rallye 4 A.S.M. Harness for several years. The install is very simple and uses the stock belts mounting locations. I also just fold the belts around the sides of the stock seat when I am not using it..and if you have people in the back seat the harness just unclips and the rear passengers have access to all the stock belt(s). Chuck P. would you explain your comment...? about this harness ! Pete
Old Jul 12, 2010 | 06:54 AM
rcheung's Avatar
Maybe you should do some research before posting this. The Schroth Harness with ASM technology is specifically engineered to be run without a rollcage and to be safe in the event of a rollover.
Old Jul 12, 2010 | 02:15 PM
I did use my harness on the street sometimes, but it did make me a little nervous. I was using the mouting bolts for the rear seatbelts as my anchor point for the shoulder straps. In a collision, it would have to be REALLY bad for those to be pushed forward significantly, but in my bad dreams, that's what I imagined
Yes, Schroth does have an ASM feature so you don't need a submarine strap.
Old Jul 12, 2010 | 03:30 PM
shaggy4267's Avatar
Thanks for all the feedback; definately buying a pair. I want to get more control and have grown tired of "flopping around" in the seat during autocross and such.
Old Jul 13, 2010 | 04:30 AM
It makes a tremendous difference - your arms are just working to turn the wheel, your feet are just working the pedals. Without the harness, they're partly keeping you in the seat too. All your control inputs are a bit easier and more precise.
If you drive on the street, you have to re-adjust a bit. Your turn-in will probably be more abrupt. You'll know, when your passengers complain about smacking their heads on the side windows
EvilTechnology
Feb 17, 2013 07:21 PM
EvImVictim
South Region
Mar 3, 2011 12:35 PM
Johnny09
Dec 28, 2010 12:21 PM
Steiner
Feb 12, 2009 06:49 PM
haze1995
Northwest Region
12
Feb 11, 2008 12:41 AM
