car cranks, it stops, then it dies... Any ideas
Old Jul 11, 2010 | 09:26 AM
sleeezy's Avatar
Today i get into my car to leave i try to turn it on but it doesn't. It cranks then stops and the car dies. I try it again but this time the car doesn't even crank and the lights on the gauge cluster does not even light up. I pop the hood to find out whats wrong get out and then close the door to hear my alarm go off. I turn it off to find that now all gauges have power now. So now here I am trying to figure out hat the problem is this time. Any ideas?
Thanks
Old Jul 11, 2010 | 01:01 PM
talonkev's Avatar
I would start by checking for loose or corroded battery terminals/wires. If you see corrosion take them off and clean them up really good.
Old Jul 11, 2010 | 02:01 PM
Crankwalked2G's Avatar
First I would check the terminal as stated before and after I would check the battery under load. If you dont have the machine than take the battery out and take it to auto-zone, they can usually check it free of charge. If the battery is good and has a full charge and your lights on the cluster still dont light up than I would check the fuses and ignition switch. If the lights on the cluster light up and the car dont crank at all I would check the starter(if it gets power, jump it and see if it spins). If that checks out good than I would check if it is related to alarm or factory anti-theft system. These are just some basics. Good luck and let us know whats going on.
Old Jul 11, 2010 | 02:05 PM
xhammerx's Avatar
mayb a loose ground...happed to mine one time. it was a loose ground around the fuse box.
Old Jul 11, 2010 | 04:28 PM
Wisky's Avatar
Any codes?
Old Jul 11, 2010 | 04:47 PM
Derock2gspyder's Avatar
ya loose power or ground cable! also had a few come in with a broken terminal also check for cracks on the terminal itself if it is broke then replace it!
Old Jul 11, 2010 | 05:21 PM
SpoolinUp's Avatar
Silver Sponsor
Sounds a lot like a fuel pump that has bit it.
__________________
-Matt- http://www.SpoolinUp.com
"Performance without the Price Tag"
Old Jul 11, 2010 | 09:26 PM
evo20025's Avatar
its gotta be something simple check the fuses
72Tornado
Jul 12, 2017 11:53 AM
KJS
Oct 4, 2016 06:58 AM
ryanholder24
Aug 29, 2016 07:08 PM
hooliganSKATE
Dec 9, 2015 07:33 PM
derekste
28
Aug 17, 2010 07:45 PM
