What size injectors should I use to push the fp black on pump gas in cold weather?
What size injectors should I use to push the fp black on pump gas in hot and cold weather without maxing out injectors and not going to big where im going to have issues with cold and hot weather start ups and idle.? I'm on a single walbro 255 pump.
I'm on a fp red with 1000cc injectors and they are about maxed out. I think 1250 will be about maxed out with the fp black. I am not sure, I don't want my car to run lean when its real hot or cold out. I also don't want anymore drivability issues than i already have. I plan on running like 31-32 Psi.
I run PTE 1000cc daily with my fp black. I live in Michigan, so the weather is just as cold here if not colder anywhere else.
I believe AMS said I was only at like 65% duty with 93 when I got tuned.
FIC 1050's will be fine for what you want. At 43.5 psi at the injector these injectors will support up to 572hp at 85% duty cycle on pump gas. 2.2 ohms and the latencies go from 1.62 @ 8 volts down to .88 @ 16 volts.
Great thing about these injectors is they are low impedence...direct replacements, no need to bypass the resistors
