Obdii port will not connet
Old Jul 19, 2010 | 07:22 AM
rodknock02's Avatar
Car is a 2003 evo viii
I tried seaching though the fourms but couldnt come up with anything. The problem i am having is that there is the cel is on and i tried to scan it and it keeps coming up with car not connected.etc and yes the key .
Anybody have this problem
Old Jul 19, 2010 | 07:30 AM
gsrboi80's Avatar
What are you trying to scan it with? A standard OBDII scanner or a laptop program (Evoscan, Scan Tech)
Could be a ECU, the port, or a scanner issue
Old Jul 19, 2010 | 07:42 AM
rodknock02's Avatar
i tried a coulpe diff scanners. im gonna try my friends snapon solist today.
Old Jul 20, 2010 | 06:30 AM
DarksideZ's Avatar
I believe the OBD-2 port gets its power from the dome light. It might be a power/ground issue with the port itself. I would start there.
Old Jul 20, 2010 | 07:06 AM
Bobster22388's Avatar
Check your fuses also.
Old Jul 20, 2010 | 07:35 AM
goodies's Avatar
if your using a laptop scanner (evo scan) make sure the com port setting is the one you are using, i had that problem and that was my fix, just had the usb cable plugged into the wrong com port
nokia_aid
Apr 24, 2015 06:21 PM
AlwaysinBoost
Feb 17, 2011 06:51 AM
amak87
Jun 12, 2010 05:55 PM
Gary@MellonRacing
29
Aug 7, 2009 12:58 PM
4GEvo63
15
Nov 23, 2005 11:02 PM
