transmission feels shifts notchy when shifting
Old Aug 6, 2010 | 09:56 PM
strtrcng426's Avatar
hey guys I recently had my trans rebuilt by shep and installed brass shifter bushings that goes on the trans from lancershop. I noticed when I shift it feels really notchy. I believe its because of the brass shifter bushings and I contacted mitsu and I have to buy the whole linkage in order to get the bushings. Does anyone know where to buy similar ones ? thanks
Old Aug 7, 2010 | 04:31 PM
m34g63's Avatar
if your looking for stock bushings, i have some pm me
Old Aug 7, 2010 | 04:33 PM
fareastkorean's Avatar
Did u put anything around the bushings before putting them on? If not, you should get some anti seize and rub it all around both shifter bushings. I got the buschur 2 piece under hood shifter bushings and after I applied some anti seize the car shifts so much smoother.
Old Aug 7, 2010 | 04:42 PM
Celica2EVO's Avatar
you might also just need to adjust your clutch, most likely its that and not the bushings because I have the same bushings and they are perfectly fine.
acrkid
11
Nov 18, 2016 04:03 PM
PDXRalliArt
Sep 6, 2012 06:37 PM
SeanM505
Oct 30, 2011 01:13 AM
Ralli04
Oct 14, 2008 05:17 PM
DangerousDan
Sep 4, 2006 09:29 PM
