question about short shifter and bushings
Old Oct 26, 2011 | 08:59 PM
SeanM505's Avatar
does anyone know if the AMS base bushing set will fit on the torque solutions short shifter? i want a good short shifter but i hear you have to add the bushings in order to get rid of the grinding notchy feel that all of us seem to be experiencing, atleast on these 2011 models. im sick of it!
also does anyone kno about the works short shifter and bushings set? will the ams bushings fit on the works shifter?
Old Oct 26, 2011 | 09:03 PM
evokerfes's Avatar
The base bushings don't go on or in the short shifter. The base bushings replace the rubber bushings at the base of the shifter assembly. You can mix and match. I have AMS base bushings, AMS underhood bushings, and a Works Short shifter.
Old Oct 27, 2011 | 10:35 AM
TWM Performance's Avatar
If you want the ULTIMATE short shifter for your car, you need this:
http://www.twmperformance.com/shorts...rtshifters.htm
We also have all the bushings you need and ready to ship!
Old Oct 27, 2011 | 05:54 PM
SeanM505's Avatar
too expensive
Old Oct 28, 2011 | 10:46 AM
Originally Posted by SeanM505
too expensive
Here's just the bushings:
http://www.twmperformance.com/bushin...ushing-kit.php
Patrick
Team TWM Performance
Old Oct 29, 2011 | 11:05 AM
No_Skillz's Avatar
Underhood bushings and transmission arm bushing made the biggest difference in my 2011. Also, trans started to become smoother shifting after wearing in after 8k miles or so.
Old Oct 30, 2011 | 01:13 AM
Horus's Avatar
I have a 2011 and got the works short shifter and bushings set which included the base bushings and under the hood bushings. In order to get the most out of this mod, it's best to get all of these and then do the Redline Transmission Fluid Cocktail (2 qts of MTL and 1 qt of Mt-90). For a daily driver, this is the most comfortable as well as say goodbye to notchiness... IMO if you leave out one of the above, you just won't get the full effect. My shifter now glides into each gear like butter.
Kracka
83
Jan 20, 2017 12:54 PM
j_barcarse
Apr 10, 2013 07:14 AM
wilsonevo8
Mar 5, 2013 10:27 AM
tck253
Evo X How Tos / Installations
Mar 13, 2012 09:02 AM
Spec-Ops1
12
May 20, 2011 09:12 AM
