HELP Grinding noise
Old Aug 23, 2010 | 10:28 AM
Wiggb's Avatar
HELP Grinding noise
My 05 evo just started making a grinding noise from the front passenger area it sounds like to me it coming from the brakes or rotor but I have no idea I can only hear it when I let of the gas Please help! Also stops for a few seconds when I slam on the brakes???
Old Aug 23, 2010 | 10:31 AM
C_LosEvo's Avatar
have you check if you have any brakes left? Thats the sound my car make when i need new brakes.
Old Aug 23, 2010 | 10:38 AM
mtxfrk2k1's Avatar
probably hitting the wear indicator on the brake pads. dont wanna brake to hard or go to much longer. hotspots develop easier because pad cant disipate heat as fast.
Old Aug 23, 2010 | 12:03 PM
WhItEVIII's Avatar
Like they said check your brakes but I know when it is the brakes it does that noise when you do hit em. Unless your down to full metal to metal might wanna have a look ASAP.
Old Aug 23, 2010 | 12:05 PM
XxApollynxX's Avatar
Like they said probably low on pad life, i'd take the wheel off and take a peak in there to see what your currently riding around with then go from there.
Old Aug 23, 2010 | 12:31 PM
ratwals's Avatar
Check your pads and rotors. If your pads and rotors look ok, check and make sure that the caliper is retracting all way when you release the break pedal.
Old Aug 23, 2010 | 12:55 PM
gsrboi80's Avatar
Also check that your backing plate isn't bent in a little and glancing the rotor as it turns if the brake pads are ok
Old Aug 23, 2010 | 08:59 PM
jy951's Avatar
Make sure your lug nuts are tight.
Old Aug 23, 2010 | 09:09 PM
Marroccowned's Avatar
I'm having the same problem...I'm going to replace my rotors and pads
