evo 1 valve question kinda 1g and 2g 4g63 valves any different?
Old Aug 25, 2010 | 06:33 PM
mot_bot's Avatar
Im just curious as to if the 1g and 2g 4g63 valves are any different. I cant remember if evo 1 4g63's use 1g or 2g parts.
It would seem that they would use 1g parts to be correct with the era, but I seem to think when I got the waterpump for it I had to get a 2g as the 1g wouldnt fit.
thanks,
Mathew
Old Aug 26, 2010 | 12:05 PM
MRpunk's Avatar
I am almost certain that the valves from the 1g and 2g are the same. If I remember correctly the rocker arms and valves are both identical. I think its just the lifters that are different. The 1g has a smaller hole in the top of the lifter then the 2g. Let me double check on that and I'll get back to you.
Old Aug 26, 2010 | 03:49 PM
still*boostn's Avatar
if this helps i just took my brand new daul springs and ti retainers off my 1g 6bolt head and has them put in my evo 9 head(they were new.).
when i asked supertech if the springs could work in the 9 head they said yes, that they are exact same heads,... so i would think the answer toy our question is yes.
Old Aug 29, 2010 | 11:54 PM
mot_bot's Avatar
thank you for the feedback everyone
Old Aug 30, 2010 | 04:33 PM
94AWDcoupe's Avatar
the valves interchange just fine. but evos from 1-9 came with a filled exhaust valve that copes with heat better. it will have a 6N on the face of valve. the intake will have 6T. all the 1g and 2g cars came with 6T intake and exhaust.
Old Sep 1, 2010 | 06:08 PM
Yota Eater's Avatar
Veteran: Air Force
Exclamation The valve trains differ...
DSM 1G
Intake valve: MD127840
Exhaust valve: MD127841
Valve springs: MD139243
DSM 2G
Valve springs: MD185870
EVO 1
Exhaust valve: MD184078
EVO 2-3
Exhaust valve: MD130164
EVO 4-7
Exhaust valve: MD184078 (sodium filled)
EVO 8-9
Valve springs: MN158946 (beehives)
Old Sep 2, 2010 | 06:22 AM
mot_bot's Avatar
Originally Posted by Yota Eater
DSM 1G
DSM 2G
EVO 1
EVO 2-3
EVO 4-7
EVO 8-9
hmm interesting, and kinda ****ty. where did you get those sources from? Considering others have interchanged dsm and evo 9 valves(same as evo1) would it technically be fine?(just wont be sodium filled)
its jsut there is quite a noticeable difference on valve pricing on 1g and 2g vs evo 8 :/ and im really pinching here
Old Sep 8, 2010 | 08:45 PM
Yota Eater's Avatar
Veteran: Air Force
Thumbs up
My source is the Mitsu ASA progs (JDM and USDM) current up to JAN 2010. Its true that you can mix and match the parts, but installing the EVO 8/9 parts is the best from stock selection.
Old Sep 9, 2010 | 08:34 AM
mot_bot's Avatar
Thanks for the response. Although I would like to have gotten the correct evo valves money didn't allow me to so I'm waiting for some dsm valves. Thank you everyone for your input
Ichigo0Soul
May 23, 2016 09:02 AM
senate6268
128
Sep 3, 2015 10:44 PM
06MRericctho
Sep 10, 2010 10:25 AM
berkey
16
Oct 31, 2007 10:33 PM
