Is it worth it? intercooler and pipes
Old Sep 4, 2010 | 06:52 AM
FJF's Avatar
FJF
Originally Posted by v8<turbo4
Any one know how much power i would lose by not installing the upper IC pipe and just keeping my stocker
None. An UICP does virtually nothing. A LICP might net you a consistent 3-4whp in the current state of tune.
Old Sep 4, 2010 | 07:20 AM
onewickedninelv's Avatar
I also noticed a little bit quicker spool up with LICP.
Old Sep 4, 2010 | 08:03 AM
gsrboi80's Avatar
Only issue I have ever seen with the stock UICP is the upper rubber hose will start to ballon to **** once you start getting some extra boost in the car.
Doesn't really have an effect as long as it stays together
Old Sep 4, 2010 | 09:30 AM
Karass's Avatar
I heard the stock IC is fine enough for ALOT of power? I know of a rally team running with stock headers and IC with more than 25k$ on the engine only. They have been running in rally since the evo 6 so they know alot about the car (and they are own a mitsubishi dealer).
So my question: why are people changing their stock IC unless they aim for monster power?
Old Sep 4, 2010 | 09:41 AM
gsrboi80's Avatar
Heat soak is a beotch. Go out and log 10 back to back pulls you'll start to see the picture a little more clearly
Old Sep 4, 2010 | 10:08 AM
impact blue's Avatar
Does this go the same for a stock turbo with just bolt-ons?
Old Sep 5, 2010 | 02:07 AM
FJF's Avatar
FJF
Sure, your setup won't see any significant gains, either, with just the piping.
Old Sep 5, 2010 | 08:15 AM
DJAfterShok's Avatar
You will deff notice a diffrence in spool time also.
Might need to upgrade some of the fuel system also if your still running on stock.
Old Sep 5, 2010 | 08:19 AM
FJF's Avatar
FJF
Can you point to a dynograph that illustrates such a thing? I've yet to see one that shows decreased spool time on a stock-ish car.
For pipes? Why?
Old Sep 5, 2010 | 12:14 PM
OMEGA PHX's Avatar
Get the IC its worth it
Old Sep 5, 2010 | 05:20 PM
jy951's Avatar
I don't think you'll notice much difference just driving normally on the street. During street driving you're not likely to get heat soak.
I had my care tuned recently with only a mbc, downpipe back exhaust, test pipe and drop in k&n and made 298 on a mustang dyno. I'm sure a bigger intercooler will help with higher horsepower, but with the stock turbo on the street I think the stock intercooler is fine.
Old Sep 5, 2010 | 07:02 PM
So your saying the stock intercooler will suffice? but up to what peak in whp ?
Old Sep 6, 2010 | 01:40 PM
thedru13's Avatar
I think its worth the upgrade. I can't wait to upgrade from the Stock IC. I think you would be happy with the upgrade.
Waldo
Feb 5, 2012 03:17 PM
Evo1001
Jun 21, 2010 10:22 AM
IAmADirtDude
Aug 14, 2008 11:43 AM
mscorei
20
Mar 5, 2008 06:45 PM
