idle fluctuation after resetting ecu.
Old Sep 8, 2010 | 08:48 PM
Charlie-Y's Avatar
Hello ,
just a week ago I pulled out the battery to replace the shifter bushings , and
put back the oem bov.
After the battery was put back I went for a drive to have the ecu relearn.
normally it would idle bad for a few minute than return to regular idle(500rpm)
For some reason the idle would fluctuate while stoping at the stoplight , I thought
the car was going to stall but it didn't.
any ideas where to look?.
Old Sep 8, 2010 | 09:13 PM
Jmelocik@Spec-Ops's Avatar
you have to let the ECU relearn the trims in all three trim states: LTFT low, LTFT mid, LTFT high. low is generally considered the idle trim with mid the cruise trim. If you didn't let it idle for about 15-20 minutes after reconnecting the battery it may not have had enough "cycles" for the idle trim to settle out to a steady state. This may be causing the poor idle when you come to a stop. But I'm also not the tuner, I'm the engine builder/mechanic/sales/parts warehouse/tool guru so don't really pay me much attention. LOL j/k
Josh
Old Sep 9, 2010 | 01:34 PM
7EVO7's Avatar
Let it idle...
following these steps, 5min each:
1) no electrical thing turned on
2) a/c and radio
3) a/c, radio, lights, rear defogger
succesfully tried and tested, so the ecu can learn it various idle loads (that's my conclusion).
please, report back your results.
Old Sep 9, 2010 | 03:52 PM
Charlie-Y's Avatar
2) a/c and radio
Interesting, I will try that to see if it helps, thanx.
Old Sep 9, 2010 | 04:52 PM
YogSaahoth's Avatar
Veteran: Army
Usually takes mine a few days to return to normal...it will be fine just keep driving it like u normally would
Old Sep 29, 2010 | 05:35 PM
Charlie-Y's Avatar
2) a/c and radio
Update!,
It works Id try other things but it didn't work so I give this a shot , take the car for
10-20 minute drive in various speed, car purrs smoothly now.
Thanks guys.
clanzkiller
25
Mar 15, 2017 09:55 PM
Raptord
Oct 23, 2013 06:46 PM
lapoune
Aug 22, 2012 03:47 PM
Smurf Rocket
24
Oct 22, 2010 06:00 AM
fengzhaoxi
Apr 3, 2010 10:54 PM
