Intercooler sprayer
Old Sep 9, 2010 | 01:57 PM
fwd_josh's Avatar
Question Intercooler sprayer
I've searched and haven't found what i'm wondering. Maybe some one can point me in the right direction. When put in AUTO mode does the ECU control the sprayer? And what parameters trigger the sprayer? and if the ECU controls it, can these be modified when the car is tuned?
Old Sep 9, 2010 | 05:35 PM
sirsol's Avatar
I'm very interested in this as well, at first I thought the IC sprayer was pretty neat but honestly, I have not used it since the second week I purchased the car. Plus, a filled tank is a lot of dead weight at a polar end of the car, so the weight savings could definitely be worth it if you were to just rip the whole system out.
Old Sep 9, 2010 | 06:14 PM
still*boostn's Avatar
been awhile since i had an evo 8 but i think in auto it cuts on at WOT.
try turning the ignition on and putting the pedal to the floor to see, but then again the engine might need to be on.
Plus IMO, The spray would be GREAT with ice in it in the summer time, esp if your still running the stock IC.
Old Sep 10, 2010 | 10:21 AM
barneyb's Avatar
Yes, the ECU controls the sprayer in auto. From what I've read there is a long series of conditions that have to be satisfied before the sprayer will spray. The threashold of these conditions are set to only be satisfied in extreme (racing) conditions and then th ECU is very frugal with the water so that the water carried will last the duration of the event.
Old Sep 10, 2010 | 11:07 AM
fwd_josh's Avatar
So can the parameters in the ECU be changed? Maybe on of the tuners can chime in.
Old Sep 10, 2010 | 11:17 AM
evremonde's Avatar
do a search for the tephra mods (ecu section). They have ecu updates for better control over the I/C sprayer. Even if you just wanted to change the thresholds, this would be good place to start your research.
Old Sep 10, 2010 | 02:00 PM
fwd_josh's Avatar
found lots of info. thanks for the point in the right direction. I was looking in the wrong places.
92LaserRs
Jul 17, 2013 08:26 PM
lancer586
Jan 29, 2011 12:13 PM
TurboTravis
AEM EMS
Sep 7, 2010 03:29 PM
badev0
Jun 4, 2010 04:21 AM
evotino
Sep 14, 2005 08:11 PM
