Best Gauge Pod and Place to Put!?
Yeh i just kinda started thinking about that lol.... GREAT postion but if it was a little lower it would be better... but most of the steering wheel mounted pods get in the way of your speedometer n stuff... the Autometer looks pretty good on this? What do you think?
Like this THIRD PIC DOWN in the FS thread
https://www.evolutionm.net/forums/sa...or-tranny.html
I think the BEST place for the gauges are the ( EVO X ONLY
) CP-e Dash mounted pod!
http://www.youtube.com/watch?v=y5Wzyp7aQxI
) CP-e Dash mounted pod!http://www.youtube.com/watch?v=y5Wzyp7aQxI
I believe the company was AIT.
I have my boost and A/F gauge on the steering wheel, one is a 60mm (Defi boost), the other a 52mm AEM wideband.
The three gauge pod is Gruppe S, with 60mm Defi oil temp, oil pressure and EGT.
How do you like this setup. I have been contemplating it but not sure. How easy is it to read, i cannot tell from any of the pictures i have seen with this installed on how well the angle is to see from the drivers side without it being a distraction. Err well i hope that made sense.
Thanks
Thanks
The Gruppe-S 60MM pod with Defi's you can set minimum and maximum alarms that will beep or alert you if a sensor is above or below a certain threshold. If you are concerned about overboosting, low AFR or anything else, program failsafes into your tune / ECU.
I have been looking EVERYWHERE for a dash mounted pod similar to the ones CP-E makes for the evo x
Anyone know of anything like it?
NOT THE CENTER DASH PODS! Those are just hard to see...
, wow that looks dangerous i have a triple gauge pod that replace my little cubby below the radio and hvac controls, people cant see it when goin by, its stealth mode
It's easy ... but seriously whose sitting there watching the gauge when they are supposed to be driving???
http://www.youtube.com/watch?v=toNz32UdmfQ
Gruppe S 60mm gauge pod + radio relocation kit = Clean setup
I definately agree with that . I don't know how someone can get away with mounting the gauges there. If he/she ever got pulled over i am pretty sure they would give them a ticket. Especially with how stupid they are getting about having thigns mounted to your windsheild these days.
