stock cat 02 sensor
Old Sep 24, 2010 | 09:57 AM
elmark44's Avatar
stock cat 02 sensor
so i hve a question before install on my test pipe/downpipe !
does most people remove the 02 sensor in the stock cat OR put a BUNG in the test pipe...
i got an megan downpipe with a bung on the end with 02 sensor for my AEM wideband... do i need to put another one in test pipe?! or installl test pipe and remove the Engine light..
Old Sep 24, 2010 | 06:59 PM
polish_pounder's Avatar
you need to get a spacer for the 02. its not in the cat its behind it your test pipe will fit in between your two sensors. you need to space the sensor behind the cat out so that it reads no change in your exhaust and will not throw a code. thats what i just did with mine
Old Sep 25, 2010 | 06:21 AM
elmark44's Avatar
ok, i guess i buy the car with a rear sensor in lesss cause i got an HKS hi-power for cat back and no sensor on it .
Old Sep 28, 2010 | 12:01 AM
mesoevo's Avatar
where are you in canada?
Old Sep 28, 2010 | 09:42 AM
elmark44's Avatar
im in qc !
Old Sep 28, 2010 | 10:22 AM
EvolutionVIIIrs's Avatar
go to your local auto parts store and find the Help! section... they have a spark plug rethreader. Weld in bung to test pipe, screw said spark plug rethreader in, and screw 02 sensor into that. It backs the sensor out roughly 2", making it not read the "true flow" being its no longer sticking into the test pipe, but in the void space of the spark plug rethreader. Wont throw any codes!!! Just be sure to check the 02 sensor wire that its not touching the frame rail, otherwise itll rub and ground out, throwing your CEL!!
Here ya go. Heres what im talking about. and only $8
http://www.amazon.com/gp/product/B00...HYRS54YQYERW6B
RedEvoxGSR
Jun 15, 2010 10:47 PM
EvoSeanzie
Jun 12, 2010 06:58 AM
widge
15
May 4, 2010 07:52 PM
ksattic
Jan 31, 2009 06:00 AM
BlackonBlack2
10
Sep 28, 2008 09:47 AM
