Want to Purchase a Built short block ?s
Old Sep 27, 2010 | 12:55 PM
navysandsquid's Avatar
Thanks for all the info I already have big cams
Old Sep 27, 2010 | 01:05 PM
BLKCarbonEVO's Avatar
Hope you are not talking about the Kelford 272s... Those are not even close to being "big"...
Mikey
Old Sep 27, 2010 | 01:18 PM
ChrisCarey's Avatar
Originally Posted by blackgsx01
what all different parts do you need for a 2.4? like timing belt kit, head gasket, waterpump. Do you have a 2.4 conversion package?
We have a 2.4l water pump adapter plate and can certainly help you in sourcing a head gasket (PE / Cometic Phuzion / AMS Modified) and timing belt in a package
Old Sep 27, 2010 | 02:28 PM
Originally Posted by ChrisCarey
Thanks for the referral guys The reason for the difference in pricing mostly involves the core charge as the 2.4's are cheaper to source than a stock Evo core. With that said our pricing should be very competitive, our customer service is unmatched, and the results in my signature speak for themselves. Please let me know if I can be of any assistance!
Thanks for all your help and honesty on the phone Chris. I look forward to working with you. in the near furture.
Old Sep 27, 2010 | 02:31 PM
ChrisCarey's Avatar
Anytime sir
Old Oct 1, 2010 | 03:04 PM
What would you guys recommend for Compression ratio on a 2.4 I talk to the shop I'm working with and they said 9.7 was probably a little high.
Old Oct 1, 2010 | 07:59 PM
ChrisCarey's Avatar
Pump gas or E85 sir? In all honesty either way 9.7:1 will be acceptable, some of the more recent builds on E85 are 10.5:1 or higher.
Old Oct 1, 2010 | 08:04 PM
EvoDan2004's Avatar
why not do a 2.1L motor? whats wrong with them?
Old Oct 2, 2010 | 10:37 AM
BigBADGSX's Avatar
Buschur builds the best...you would almost be crazy to go elsewhere. Good luck with your build
Old Oct 2, 2010 | 11:02 AM
I think a LR2.1 (4G64) would be nice if you plan to build a straight race car that lives at the track. Most people now days like a very streetable setup. I personally feel that the LR2.4 (4G64) is the best motor on the road. You get all the goods and none of the bads. A LR2.4 can handle 8500-8600 daily and I would feel safe saying even 9k at the track.
I don't think there is anything wrong with a 2.1, I just think it is not what a lot of people are looking for. I went from a 530hp stock 2.0 to the 650hp LR2.4. Let me tell you that it is night and day. I have great downlow power that the 2.0 didn't have. I can also rev 1000rpm higher than the stock motor. I can talk all day about how amazing my motor is.
Aaron at ER has a LR2.4 just like mine and he said that it would take a lot for him to leave the LR2.4. He has had every motor combo possible and the LR2.4 justs makes more power, can run almost as high rpms, and is much more fun on the streets than any motor he has had, even topping his wild high compression 162mm LR2.2 that he built last year.
I look at my motor - 10.3:1 MIVEC LR2.4 (4G64) much like the Nissan guys look at the RB30/BR26 hybrid. That is pretty much the same thing we do. Take the larger block and mate the performance head to it and do some custom work to make the larger block rev happy Our 2.4s can rev, Kevin revs his std 2.3L to 9250rpms and the LR2.4 is a much happier revving motor than the std 2.3.
ER imho is the best shop for your LR2.4 builds. They have built more than any other shop and they have been building other long rod motors for years! This is nothing new to them.
Mikey
Old Oct 2, 2010 | 11:13 AM
shuttlegoose's Avatar
Mikey
would the 10.5 comp motor not be good to run for 93 octane? And about running a larger cam, what about those of us on the stock ecu? Im sure arron can take care of that because he is the master of all things tuning and stock ecu, but what about those of us on the east coast lol.
Old Oct 2, 2010 | 11:43 AM
RockmanX's Avatar
all i know is that im not running 10: to anything compression on pump gas waste of time. I had no e85 availble where i lived ill pass on that. 9: etc it perfect on pump.
Old Oct 2, 2010 | 09:30 PM
EvoDan2004's Avatar
a 2.0l built motor can turn 10krpm. im told a 2.1l can turn 11k rpm. granted this is not ideal but when u need to spin a motor ''drag cars'' u need all the rpm u can get. and doesn't a 2.1l make a little more TRQ then a 2.0l motor would? or no.
Old Oct 2, 2010 | 09:46 PM
detroit pistins's Avatar
u'r correct! from the research I have done, the 2.1 has lower sidewall loading and slower piston velocity vs the 2.0
Old Oct 2, 2010 | 09:54 PM
EvoDan2004's Avatar
so if a 2.1 makes more trq then a 2.0L and revs higher then any other motor why even bother with a 2.2/3/4L motor that looses peak RPM as the displacement go's up?
