05 evo 8 transfer case
Old Sep 28, 2010 | 01:02 AM
Bebe_82's Avatar
hi.
a 05 evo 8 tranfer case will fit on a 06 gsr evo 9? or any different between this two transfer? thanks.
Old Sep 28, 2010 | 02:53 AM
Berts24's Avatar
If I'm not mistaken the it will fit but the 9 has the ACD and the 8's don't so therefor you're downgrading and you won't be able to use the ACD. But it should bolt up fine why would you want to do this?? Because an 8 tcase is cheaper?? It's cheaper for that reason plus some might say not built as strong
Old Sep 28, 2010 | 03:20 AM
MR. EVO MR's Avatar
03 and 04 didnt have it
the 05's 8's have acd
Old Sep 28, 2010 | 03:51 AM
NJ_EveOhVIII's Avatar
i had an 06 ACD tcase in my 05 ACD so i would only assume.
Old Sep 28, 2010 | 07:35 AM
warstang27's Avatar
theyre the exact same thing it will fit
Old Sep 28, 2010 | 09:42 AM
Sil'vr-Boi6's Avatar
05 acd = 06 acd
+1...^ I have a 05 GSR with ACD stock. And replaced my destroyed 05' ACD with a IX ACD. Same thing.
Old Sep 28, 2010 | 09:53 AM
Bebe_82's Avatar
thanks!!! 06 is stronger than than 05?
Old Sep 28, 2010 | 10:04 AM
chaotichoax's Avatar
afaik they are the same part number
Old Sep 28, 2010 | 10:19 AM
EvolutionVIIIrs's Avatar
listed on mitsubishiparts.net as the same part numbers
Old Sep 28, 2010 | 10:47 AM
DarksideZ's Avatar
It should be the same T-Case.
Old Sep 28, 2010 | 10:59 AM
raiceboi697's Avatar
while you do lose ACD functionality with a non ACD case, the ACD t cases are not as strong because there is more stuff crammed into the case for the ACD and once there is more power its easier for you to destroy it. but again i dont know your end state goals with the car or what power level its at. just giving my .02 though
Old Sep 30, 2010 | 05:44 PM
Bebe_82's Avatar
why i'm going to lose the acd functionality? a 2005 evo come with thae acd.
Old Sep 30, 2010 | 06:01 PM
kousayee's Avatar
its the same thing, nothing changes
Old Sep 30, 2010 | 07:41 PM
talondex's Avatar
same thing
Old Sep 30, 2010 | 11:44 PM
Bebe_82's Avatar
thanks!
Justin23
Dec 13, 2016 09:03 PM
Yota Eater
Sep 13, 2016 01:27 PM
EvoVIII :D
Aug 14, 2016 07:28 AM
Soupraman
Jul 5, 2016 11:21 AM
fd2ap2e92
West Region
Oct 22, 2015 03:21 PM
