uicp advantage?
Old Oct 16, 2010 | 11:03 AM
4bangers's Avatar
uicp advantage?
from reading around i know that aftermarket licp help free up the stock pipe restriction. however, is the stock uicp restrictive and changing it out will will see any gain?
Old Oct 16, 2010 | 11:11 AM
01 Trans-Am WS6's Avatar
I hear the UICP does not really show any gains, however the LICP is a completely different story, put them on you will see gains.
Old Oct 16, 2010 | 11:18 AM
erald01's Avatar
The oem one has no restrictions, if u get the short route one it will prolly free 5whp, but u also need to switch to a small battery kit, the oem ones are good to 400 whp then the cplrs will start blowin(not all the time but i seen it happen), but other than that the oem one is pretty good
Old Oct 16, 2010 | 11:22 AM
GgreyEVOIX's Avatar
I changed out my UICP when I did the FMIC & LICP.
It may not add any hp but the stock upper pipe does blow off sometimes and the stock rubber hose does balloon under boost.
Old Oct 16, 2010 | 12:33 PM
FJF's Avatar
FJF
Originally Posted by 4bangers
...is the stock uicp restrictive and changing it out will will see any gain?
Nothing for the UICP and maybe a few of HP for a LICP on a stock-ish car.
Old Oct 16, 2010 | 07:46 PM
rdt1's Avatar
Are these gains from the LICP real? Anyone test this?
Old Oct 16, 2010 | 07:49 PM
EvoJoeIX's Avatar
the only time id go to a aftermarket UICP is when you use a tial bov cause you need the flange welded onto the pipe
Old Oct 16, 2010 | 10:51 PM
Jp7's Avatar
Jp7
Something to think about:
OEM piping on the IX, and VIII I know have alot of aluminum on them. The aluminum transfers a high degree of heat. Meaning heat from your engine really does a good job of getting through the aluminum into the air traveling towards your manifold.
My ETS Upper and Lower pipes are made of stainless steel. Stainless steel has a lower thermal transfer coefficient, meaning high engine temperatures will do less "damage" to the air thats been cooled by your FMIC.
Old Oct 17, 2010 | 03:22 AM
FJF's Avatar
FJF
Heat transfer works both ways. SS may take longer to heat up, but it also takes more time to cool down.
Old Oct 17, 2010 | 09:00 AM
Jp7's Avatar
Jp7
but with the intake stream you only want heat transfer from the fmic itself, not the plumbing.
Old Oct 17, 2010 | 09:04 AM
FJF's Avatar
FJF
Sorry, how does this relate to what I said?
Old Oct 17, 2010 | 09:16 AM
FJF's Avatar
FJF
Sure, it's been tested to some extent. Higher HP cars have been known to benefit significantly from an upgraded LICP. Mildly tuned stock-ish cars, not so much.
Old Oct 17, 2010 | 10:27 AM
djikonatx's Avatar
trying toget back on subject.....its there an advantage with going with a short routeother than looks and space.?
Old Oct 17, 2010 | 12:27 PM
Boosted Tuning's Avatar
Number one gain from a shorter UICP is transient response.
Old Oct 17, 2010 | 09:04 PM
savagejay1's Avatar
Haven't installed mine yet, but i've heard there are some gains. I've been told the main benefit to having an aftermarket LICP is that the turbo will spool quicker.
