uicp advantage?
Old Oct 17, 2010 | 09:10 PM
vegas702evo's Avatar
The UICP does not give you the greatest benefits compared to the LICP; however, it does improve response.
Old Oct 20, 2010 | 12:02 AM
4bangers's Avatar
what's a good brand of licp? and size?
I'm assuming 3" and ets or nesei?
Old Oct 20, 2010 | 12:22 AM
fugiwara's Avatar
go with Muse licp, very good quality and price, fitment is excellent.
stock rubber hose blows even on less 400whp car. replace them with samco silicone hose is the way to go. don't go with the mini battery setup if you are going to do short route setup.
Old Oct 20, 2010 | 12:41 AM
06RedRalli's Avatar
If you go short route...a mini battery is required.
Old Oct 20, 2010 | 12:58 AM
ElectrIX Blue's Avatar
What r u talkin bout? Like said above you have to run the mini battery if you decide to go with the short route uicp. A short route uicp will not fit on a stock battery.
Old Oct 20, 2010 | 01:15 AM
da_yo's Avatar
The short route uicp will fit with stock battery if you relocated to the trunk, maybe that's what he meant.
Old Oct 20, 2010 | 10:57 AM
djikonatx's Avatar
^^^ that our someone here made it fit by turning the battery sideways.ill never switch outmy optima for a mini....
Old Oct 21, 2010 | 12:03 PM
4bangers's Avatar
^^^ what's wrong with mini batt? does it not have enough power?
Old Oct 21, 2010 | 12:54 PM
TxEvo8's Avatar
^^Minis certaily have less than the OEM, and it's an additional $300.
Old Oct 21, 2010 | 01:33 PM
djikonatx's Avatar
^^^ that and why would you ever wanna downgrade.....always upgrade...just like woman..lol nufff said
Old Oct 21, 2010 | 01:41 PM
erald01's Avatar
mini batteries have known to fail and drain quick i know plenty of people that have got stuck at parking lots cause the mini battery doesnt feel like starting. If you upgrade the uicp, the best way is the short route ones, better throttle response, less bends which means less restriction, and relocate your battery in the trunk. LICP does make a difference and you will notice it once you put it on, the car will pull harder and the spool is quicker.
Old Oct 21, 2010 | 01:59 PM
chaotichoax's Avatar
you'll gain some transient response from a short route UICP (noticeable? ehhh)
the biggest advantage of changing the UICP is losing the stock couplers which can expand significantly under boost
Originally Posted by rdt1
Are these gains from the LICP real? Anyone test this?
search, it's been documented
a tuned car with an aftermarket LICP can add 10-15 wtq over the stock LICP
Old Oct 21, 2010 | 02:32 PM
ETS Michael's Avatar
I was just about to type out this exact response. Thanks!
Michael
Old Oct 21, 2010 | 02:44 PM
Boost Demon's Avatar
Veteran: Air Force
The stock black hoses tend to leak over time, especially when pushing a few ponies through while using the stock clamps.
zenoise
10
Oct 8, 2012 03:50 PM
sLowEvX
Apr 13, 2012 12:34 PM
Wht9er
14
Nov 30, 2010 08:07 PM
Tractionlimit
Feb 19, 2009 07:07 PM
RedLanEVO
Nov 26, 2007 07:34 PM
