shifting problem
Old Oct 19, 2010 | 09:38 PM
Alexl08's Avatar
shifting problem
Does anyone else have a problem with the car (evo 8) acting like you pushed the clutch before you left off the gas while shifting sometimes my car will rev like im still on the gas when i hit the clutch to shift. Really no big deal just annoying
Old Oct 19, 2010 | 09:49 PM
pwrofturbo's Avatar
What. I assume you mean your clutch is slipping, in which case it needs to be replaced.
Old Oct 19, 2010 | 09:54 PM
Spoolin4g63's Avatar
thinks its time to replace your clutch.!
are you still on stock.? aftermarket? a little more details will help
Old Oct 19, 2010 | 10:04 PM
rdt1's Avatar
I do from 3 to 4th..
Old Oct 20, 2010 | 01:02 AM
Alexl08's Avatar
Brand new clutch it's an aftermarket stage 2 act it's not like the clutch slips it's more less like I push the clutch while I'm still on the gas but I'm not
Old Oct 20, 2010 | 06:31 AM
Alexl08's Avatar
im thinking maybe its a bad tps sensor but then again its does not do it every time so idk
Old Oct 20, 2010 | 07:15 AM
Alexl08's Avatar
DTC P0121: Throttle Position Circuit Range/Performance Probl it put this code out today and ive gotten it once before but like a month ago maybe a problem what do yall think
Old Oct 20, 2010 | 11:14 AM
Alexl08's Avatar
Close this thread Cuz she blew up today so who cares about shifting now
Old Oct 20, 2010 | 11:39 AM
Pure EvoIX's Avatar
ouch! what exactly happened?
Old Oct 20, 2010 | 11:41 AM
savagejay1's Avatar
Damn... How did it blow up?
Old Oct 20, 2010 | 06:34 PM
SpecialNeeds's Avatar
i know what you're talking about, I have it too, I thought it was me though, slightly still on throttle when I tipped the clutch in, considering IM used to clutches engaging lower down in the arc/
was your blow up related to this issue?
sorry to hear your engine blew
Old Oct 20, 2010 | 08:34 PM
Alexl08's Avatar
You know I'm not really sure what caused it. I pulled my car outta the garage today and it stumbled on the idle a little and I was getting out while it was runing I reached my foot in there to give it a little gas a saw a puff of smoke from the exhaust it was smoking from the dip stick tube the head vent that goes to the catch can. Compression test reviled 185 psi on cylinder 1-3 but #4 blew 70 psi
Old Oct 22, 2010 | 04:42 PM
alex, is your car stock?
