Meth Injection or E85
Old Oct 29, 2010 | 07:17 AM
fqjdmct9a's Avatar
E85!
Old Oct 29, 2010 | 09:27 AM
Jerm__'s Avatar
E85 is insane dude. If you have access to it, definitely that over the meth injection.
Old Oct 29, 2010 | 09:34 AM
boostedwrx's Avatar
E98 ftw!
bluebanana23's Avatar
Why aren't people doing map switching instead of this cumbersom barrell crap?
Old Oct 29, 2010 | 09:39 AM
boostedwrx's Avatar
Because you should get all of the pump out of your system before switching maps. What a pain in the ***. Even if you drain your gas tank you'll still have ~1 gallon of pump in there. If you have E close to you just run it all the time.
Old Oct 29, 2010 | 09:50 AM
SmurfZilla's Avatar
I switch back and forth and have ZERO issues.
Old Oct 29, 2010 | 09:52 AM
SmurfZilla's Avatar
Originally Posted by GG_9_SE
E85 all the way. Your not neccesarily going to make more power with it, but you consistantly have it and never have to worry about if your failsafe on the meth kit is gonna work when u run that meth tank dry. If E85 is readily avalabel in your area do it up!
Make as much power on E as you do with Race gas or Meth
Old Oct 29, 2010 | 10:02 AM
boostedwrx's Avatar
I still wouldn't do it in my car. I want my E map close to the edge because I always know whats in the fuel tank.
E is going to be better than C16 but prolly equal to Q from everything I read.
Old Oct 29, 2010 | 10:24 AM
SmurfZilla's Avatar
Minus the pricetag. My reply was in response to the "almost makes as much power comment".
Old Oct 29, 2010 | 10:46 AM
SmurfZilla's Avatar
Old Oct 29, 2010 | 10:53 AM
jdub187's Avatar
I would definitely have to say E85 if you have access to it due to it being alot easier all around. Too much to go wrong with a meth system.
Old Oct 29, 2010 | 02:25 PM
SpecialNeeds's Avatar
I wish we had more E85 here in socal
Old Oct 29, 2010 | 02:30 PM
06MRV8Killer's Avatar
^this and I know because I used to run meth
Old Oct 29, 2010 | 02:39 PM
Ev0ikon's Avatar
I am in the planing process of building a small trailer that would hold two 55gal drums. Then it would be easier to fill them up and store them at my home. The closet E85 station is 25 miles away.
Old Oct 29, 2010 | 03:24 PM
tweaker41's Avatar
I ran on 93+meth and now I'm on e-85. Entirely new animal. I'll never run meth again. Make way more hp/tq then I did on the 93+50meth/distilled water. Its almost a dollar cheaper a gallon then 93 was as well.
