Meth Injection or E85
Old Oct 29, 2010 | 03:31 PM
  #31
drifterific's Avatar
Originally Posted by 5LEEPERISAH23I
What one is better? as in make more power?
just curious too see what people think and say
I think it all depends on the availability of e85 to you. There is only one gas station that sells E85 in my town so I chose 50/50 water/meth because of the ease for me. I think it would be an additional stress worrying about E85 stations on a road trip also. You could always run dual maps, one for pump and one for E85 if you are using Tephra mods.
I am setting up my HSF-6 to switch to a safe pump only map with lower boost in the event of a clog. I have read that it only take 3 milliseconds to switch maps. Also it depends on what you are comfortable tuning with also. I would say that you should spend some times researching the pros and cons of each alternative fuel and then make an informed decision from there. Everyone has their opinion and there is no right or wrong to either choice.
Old Oct 29, 2010 | 06:27 PM
  #32
SpecialNeeds's Avatar
how many injectors for the meth do you have?
Old Oct 29, 2010 | 07:01 PM
  #33
EvolutionVIIIrs's Avatar
Originally Posted by white_evo27
you daily drive the evo? seems like too much hassle to me since i DD and wouldnt be able to go far from home
No i dont. But if you have a buddy with a pickup truck, just order 4-55 gallon drums and youll be set. Also depends where you live tho, South Orange has the closest E85 to me, which is only 25 minutes or so away. So its not a huge deal for me.
You can also get a dual tune, and power on e85, and should u ever run out, a quick switch over to the 93, and just stay off the throttle untill u get filled back up.
Originally Posted by adam_79_2005
i doubt they'd ship barrels of e85 to hawaii but if they did, i wonder how much something like that would cost???
They do, try searching on google. Being that E85 is cheaper then 93/89/87 youd be surprised how cheap it might actually be..
Originally Posted by boostedwrx
E98 ftw!
yea. That just insane!!! I wish....
Old Oct 29, 2010 | 08:22 PM
  #34
doc29's Avatar
e85 better...meth if you dont have that at pump...
Old Oct 29, 2010 | 09:38 PM
  #35
BEISSEN's Avatar
What would be the best size injectors in this case because I want to go E85 the closest to me is 29 miles roughtly 30-45 min but I already have 1050s coming in and I will be on a FP red.
Old Oct 30, 2010 | 12:12 AM
  #36
I have one 1.0mm and am ordering a second injector (0.4 or 0.5) tonight to complete the set up. The reason I am running one right now is because I was going to run direct port injection but then changed my mind and decided on a dual nozzle set up.
Old Oct 30, 2010 | 12:38 AM
  #37
adam_79_2005's Avatar
my favorite is all the guys in the mainland who are 20-30 miles away from an E85 station. Im glad you have the oppurtunity to do so vs. living in hawaii. So therefore im forced to run 50/50 water-meth. but my ? is to everyone, why do u think water meth is a bad idea?
Old Oct 30, 2010 | 09:38 AM
  #38
I have a buschur racing double pumper fuel pump, and 1450cc injectors. FP black/ stock block. Do yourself a favor, order bigger injectors and save yourself the hassle of ordering them again later..
There are proper ways to set it up. I HAD every gizmo and gadget that Snowperformance offered. Flow gauge, fail safe, boost by-pass , warning lights etc... The problem is, theres no way with a single nozzle to control the flow of meth to each individual cylinder. Search for Mike @ AWD's thread on it. The meth isnt distributed equally. The only way to do it, would be to have 4 meth nozzles one in each intake runner. Theres a thread with someones setup on here like that.
Its just a huge hassle IMO. Then again, theres numerous people that will tell you that they have been running meth for years, with NO problems..
I personally like the corn much better!
Old Oct 30, 2010 | 02:40 PM
  #39
MarineScout13's Avatar
I know a guy that runs meth on his Evo 8 and if he can't get any or afford it his car just sits until suppliers get it back in stock. E85 is much easier since you know they aren't going to run out of it because the gas stations get restocked often.
Old Oct 30, 2010 | 03:59 PM
  #40
EvoJoeIX's Avatar
thats just dumb. he doesnt need to do that, he just chooses to.
Old Oct 30, 2010 | 10:04 PM
  #41
s13nemesis's Avatar
i have to say e85. u get crazy power out of it. but suck if u live in cold weather hard to start it i the morning lol
Old Oct 31, 2010 | 09:33 AM
  #42
eron28's Avatar
e85...i think its a lot better as long as u close with a lot of e85 stations...
Old Oct 31, 2010 | 11:09 AM
  #43
boostedwrx's Avatar
Yea thats the only thing I don't like about E. On E98 I have to start my car with starting fluid and on E85 it takes a few cranks.
Old Oct 31, 2010 | 11:18 AM
  #44
JuniorIA's Avatar
E85!! Corn fed is the best
Old Oct 31, 2010 | 11:23 AM
  #45
tweaker41's Avatar
I'm running FIC Bluemax 1450's on the stock turbo on E-85. IDC's are pretty low, mainly due to the lower fuel requirement at altitude but there is plenty of room to grow. I get the same gas mileage that I did on pump gas and it 2.29gal for E-85 and around 3.00gal for 91.
Raceghost
Jun 9, 2016 06:27 PM
neosa
Jun 27, 2010 03:24 AM
supercharged
Jun 19, 2009 08:08 PM
twinturbozs
Jan 18, 2006 11:22 AM
