Best CAMS for FP Red?
I've done alot of research and I still don't get a clear answer. I know it will be laggier than stock turbo, but I would like to get the quickest spoolup with the red out of the mods I have.
The current mod list is(Evo 9 MR):
Perrin TBE
HKS Intake
Reflash
Current WHP: 365 @ 27psi
Will Add:
ETS 3.5 FMIC with IC pipes
FP RED
880-1000cc Injectors
CAMS: ???
Goal: 430-450WHP
I'm leaning towards GSC S2's from what I have read, but I would like to get some feedback from you guys
. I'm willing to sacrifice some power in order to get better spool up. Also if there is any other supporting mod you guys think I should add, let me know! Thanks in advance
Perrin TBE
HKS Intake
Reflash
Will Add:
FP RED
CAMS: ???
Goal: 430-450WHP
a 02 housing, ported head and ex mani shouldnt be a necessity. Honestly you wont notice that much of a lag diff between the red and stock turbo. also have you looked into the Buschur 272 i have heard they are great cams also
+1 on everyones quotes except this one, come on guy yes you will notice lag going from a stock turbo to an fp red, as for the cams, i had kelford 272, but also heard great things bout s2 cams, im personally going with S3 cams on my current build, just don't forget to purchase valve springs and retainers to match the cams, otherwise you won't beable to fully extract the cams potential. Also i saw your list of mods and noticed no fuel setup? you'll need a bigger fuel pump, the 880cc should be fine, good luck.
