Ground on Fuel pump
Old Nov 2, 2010 | 04:31 AM
benderrodriguez's Avatar
Ground on Fuel pump
My ground wire recently became a little rusted, when i took off from a light it started cutting out under WOT and then backfired. Eventually the fuel pump stopped working all together when I discovered the issue. It's obvious I was going fuel lean, here are what my plugs looked like.
I'm a little worried I damaged the motor, any thoughts?
Attached Thumbnails Ground on Fuel pump-img_0310.jpg   Ground on Fuel pump-img_0311.jpg
Old Nov 2, 2010 | 08:44 AM
05blue8's Avatar
If you damaged the motor you would know it, you're fine. Running lean won't damage your motor unless you're driving it hard and in that case it should knock and pull timing so you would know something was going on and take it easy
Old Nov 2, 2010 | 09:18 AM
I appriciate this, even for just a little piece of mind. the extreem backfire had me a littel spooked, but so far it drives fine with the new pump. I'll do some WOT pulls a little later
Old Nov 2, 2010 | 10:31 AM
warstang27's Avatar
if your worried about it do a compression test and a leakdown test to see how your motor is. also a wideband gauge is your best friend lol i found that one out the hard way
Old Nov 2, 2010 | 11:55 AM
Yea my wideband cut out a couple days and then this happened at the same time. Needless to say it's fixed now.
Old Nov 2, 2010 | 12:57 PM
SLO-EVO's Avatar
your plugs dont look bad at all honestly. the discoloration from what i have personally learned is from the additives in gas. i know mine look exactly like yours 99% of the time i pull them.
OC
Jun 5, 2013 10:00 PM
Ace King
Aug 14, 2012 12:31 PM
selp
Mar 12, 2010 08:45 PM
90GSX-03EVO
Midwest Region
73
Jun 27, 2009 11:25 AM
5k6
Feb 20, 2009 07:04 AM
