Intercooler upgrade.
Old Nov 3, 2010 | 09:01 PM
240sxzenki's Avatar
My car is tuned with 360whp with the stock intercooler. If i would just swap in another bigger intercooler will that affect the tune and will it damage my engine in anyways?
Old Nov 3, 2010 | 09:03 PM
Jrah2987's Avatar
Veteran: Air Force
ETS 3.5". No damage, all smiles.
Old Nov 3, 2010 | 09:06 PM
fabshopmiami's Avatar
What he said.
Old Nov 3, 2010 | 09:07 PM
240sxzenki's Avatar
Oh how much more power will I really get if I upgrade the intercooler as of now my car pushing 360whp?
Old Nov 3, 2010 | 09:09 PM
240sxzenki's Avatar
So you guys said all gain no pain. But do I really need to re-tune the car?
Old Nov 3, 2010 | 09:15 PM
Jrah2987's Avatar
Veteran: Air Force
Absolutely need one? No.
Depending on your setup, I would do other things (piping, cams, etc.) then tune. Save some money.
Old Nov 3, 2010 | 09:22 PM
240sxzenki's Avatar
Like I said my car is tuned already. As of now it has 272 cosworth cams, forge bov and mbc, k$n intake, full turbo back exhaust, upper and lower pipes and act clutch. The only thing could have been upgraded was the intercooler.
Old Nov 3, 2010 | 09:27 PM
Jrah2987's Avatar
Veteran: Air Force
In that case I would look into fuel. Bigger injectors, pump, E85 if possible then tune it for a huge improvement.
Old Nov 3, 2010 | 09:30 PM
binky's Avatar
It's not going to affect the tune all that much.
However, because the air will be cooler, you will have the possibility of going up in load a bit.
Do you have a wideband O2 sensor installed? If so, see what the air-to-fuel ratio is when you go wide open throttle. As long as its safe, your fine
You should definitely invest in Evoscan so you can log !
-Bink
Old Nov 3, 2010 | 09:38 PM
240sxzenki's Avatar
Yeah unfortunately i don't have the wideband O2 installed in my car.
Old Nov 3, 2010 | 09:39 PM
240sxzenki's Avatar
Oh do you guys know any good intercooler out there that direct bolt on to the evo 9 without modification?
Old Nov 3, 2010 | 09:40 PM
Tfresh's Avatar
A wideband should be your next upgrade then maybe a IC
Old Nov 3, 2010 | 09:41 PM
Solley's Avatar
-Bink
I was just about to post a post like this, because I am actually upgrading to a 4" ETS front mount intercooler ( installing it tomorrow, hopefully) and i had the exact same question. everyone says its all good and that at most i might lose a pound or 2 of boost. however i am really **** when it comes to my car and don't want to screw anything up on it.
Ive got gsc s1 cams, licp, full 3" exhaust, wal. fuel pump, couple other minor things, a custom tune, and now a 4" fmic. will this be okay to put on or should i really just hold off till i get some more things then have it all installed and tuned?
also i hear a lot about Evoscan, where can i get one and how much do they run? i think this would for sure be a great investment
Old Nov 3, 2010 | 09:44 PM
djikonatx's Avatar
^^^ what reading on the wideband is considered safe.since i upgraded to the ets 3.5 and muse licp. ive noticed quite a change in mpgs. im down like 50mpgs!! average....at idle im at 14.8-15.2 ....what should be normal for wot.could it just be my tune since i just upgraded uicp and fmic...btw sorry to bud in your thread.
Old Nov 3, 2010 | 09:48 PM
240sxzenki's Avatar
^^^^ No problem. I don't mind I need to know more anyways
