never messed with this?
Old Nov 9, 2010 | 07:41 AM
Frank120's Avatar
what should i do with the ic sprayer? what mode do i leave it in?
Old Nov 9, 2010 | 09:02 AM
gsrboi80's Avatar
Use it for dual map switching. Other then that it's a useless POS
Old Nov 9, 2010 | 09:31 AM
06MRV8Killer's Avatar
As already said apparently it doesn't do much of anything... if they did they would have continued it in later models which they didn't. Dual Map switching is probably the single best use for it.
Old Nov 9, 2010 | 09:43 AM
Earthen's Avatar
Function of the sprayer is dependent on what kind of driving you do. For some it is useless, for others it has a use.
Read this thread, you will understand.
https://www.evolutionm.net/forums/ev...chime-plz.html
Old Nov 9, 2010 | 11:11 AM
3vil_3VO's Avatar
I'm getting rid of mine here pretty soon. It's missing the nozzles from the previous owner. I wouldnt use it even if it worked.
Old Nov 9, 2010 | 11:22 AM
Originally Posted by Liam@garageeast
Good read
Your kidding right? That thread was worthless...
Old Nov 9, 2010 | 11:27 AM
Noe18's Avatar
Originally Posted by 06mrv8killer
your kidding right? That thread was worthless...
lmao!!!!
Old Nov 9, 2010 | 11:29 AM
gsrboi80's Avatar
yup it reiterates the uselessness of the dumb IC Sprayer
Old Nov 9, 2010 | 11:59 AM
Earthen's Avatar
Haha, I posted the wrong link...that is why.
Old Nov 9, 2010 | 12:19 PM
^ more info in this post but still I look at it like this... Its a freaking nozzle spraying water on your IC... if there were noticable gains from this then some of the most powerful evos would be using this would they not?
I mean it would make sense for everyone to add this to their car if it truly made a difference. If there were someone who would dyno and test this for illustrative purposes then you may see a difference but the "butt dyno" I highly doubt that you can tell.
If you had a true FMIC sprayer that was pushing no2 out and chilling the IC then you would notice the difference but then the tune factor comes into play...
Just my .02, sorry to jack the thread a little.
To answer the OP, leave it in auto if anything, since its being controlled by the ECU it shold know best when it is needed
Old Nov 9, 2010 | 12:30 PM
Evoardo IX's Avatar
Reason why it is not on YOUR evo is because mitsubishi pulled out of WRC. You see, FIA rules stated that you had to have same features you have on the WRC available on the street verson car in order to homologate it for racing. That's why evo 7 (seven) has a NON functional NACA duct on the hood, because in the rally evo 7 it WAS functional. Same goes for the IC sprayer. Maybe the rally version works different, but in the end the IC sprayers do serve a purpose. So please don't go saying that they removed it because it was useless. JDM evo 9 RS comes with it, because it is likely that the car will be used for racing/rally ( I know because I have one).
Ed
Old Nov 9, 2010 | 12:33 PM
Evoardo IX's Avatar
OP, leaving it in AUTO mode won't do anything, it pretty much comes dissabled from the factory. It works based on coolant temp and I think vehicle speed also. In order to make the most out of the system, have a tuner enable it to come on at lower temps and lower speeds also, that way it will serve a purpose, a good one: to cool the intercooler a bit more. You can even put a 50/50 mix of alcohol and distiled water, so it helps cool even better.
Old Nov 9, 2010 | 01:47 PM
Ev0ikon's Avatar
It makes a great button to bypass the e-brake check for DVD players. Just take the spring out of the siwtch.
Old Nov 9, 2010 | 01:58 PM
ALSTAR's Avatar
Leave it in auto for best use.
flyinmonkey101
30
Dec 27, 2016 08:46 PM
OZRally462
Lancer Engine Tech
17
Jun 8, 2014 12:21 PM
AureOHHH
Mar 29, 2012 10:20 AM
Dmav1989
Jun 25, 2011 11:33 AM
