Clutch feels weird help!
Old Nov 12, 2010 | 02:41 PM
Frank120's Avatar
It just felt sticky and it's easier to push any Ideas?
Old Nov 12, 2010 | 08:31 PM
turbotalawd's Avatar
Sounds like either the clutch slave or clutch master cylinder is on its way out. Pop the hood and check for leaks around the seals of the cylinders.
Old Nov 12, 2010 | 11:08 PM
Frank120's Avatar
What's bump!? And where do I check?
Old Nov 12, 2010 | 11:24 PM
WolfsFang's Avatar
lol bump just means someone is bringing the thread to the top of the list.
Old Nov 13, 2010 | 01:56 PM
Frank120's Avatar
Where do I check?
Old Nov 13, 2010 | 03:25 PM
VRSF Tiago's Avatar
If you don't know where to check & not to keen on searching I'd suggest taking it to a shop. There's quite a few capable shops in your area
Old Nov 13, 2010 | 04:18 PM
Frank120's Avatar
I'm pretty convinced it's the clutch cuz there was alot of vibration in the pedal. And now it like hard to get it into 2nd and third when I shift. It makes a thunk. So I need a new clutch. I'm thinking oem, excedy stage 1 or the act street.. Idk
Old Nov 13, 2010 | 04:20 PM
VRSF Tiago's Avatar
That could still be the slave cylinder, doesn't necessarily mean it's your clutch. FYI, I've yet to meet anyone that's been satisfied with the Exedy S1
Old Nov 13, 2010 | 04:30 PM
Frank120's Avatar
Oh really!? Well idk cuz the clutch had alot of vibration in the peddle so I think I'll just replace it along with tob just to be Safe it's hard to shift also.
Old Nov 13, 2010 | 04:35 PM
Frank120's Avatar
And the vibrating in the pedal. Isn't that the pressure pate?
Old Nov 13, 2010 | 05:35 PM
Why are you immediately jumping to the problem being the clutch? Start small and work your way up. BTW a clutch pedal getting softer has nothing to do with the clutch itself. It sounds like the car needs to get checked out by a shop who knows what theyre doing if you dont know what youre doing.
Old Nov 13, 2010 | 05:42 PM
drifthobo's Avatar
get it checked by a shop before you do anything... you'll save a lot of money by not rushing to conclusions!
Old Nov 13, 2010 | 07:31 PM
bnr34rb26dett's Avatar
Originally Posted by ryno770
Bump
Old Nov 14, 2010 | 12:57 PM
Frank120's Avatar
Whats confusing me is that it's like grindy when I put it into second gear. So that's why I think it's the clutch
Old Nov 14, 2010 | 01:13 PM
evo unknown's Avatar
I highly suggest searching to find the location of the master slave cylinder. Then check it for any leaks and check the fluid level. If the fluid level drops too low, your pedal will literally get stuck on the floor one day and not come up. The master slave cylinder itself could also be going bad. These symptoms you describe are for pointing at one of the issues I just said and not that your clucth is going bad.
