Boost Issues
Old Nov 19, 2010 | 01:55 PM
  #46
4RETECH's Avatar
Originally Posted by Countrystrong11
not to many evos around here...and the ones ive talked to the guys are dicks.
I thought we were all dicks,LOL...
Old Nov 19, 2010 | 02:06 PM
  #47
Countrystrong11's Avatar
well its a different kind of dick headedness, like if he talked to me it would be cool but he just shrugged me off and walked away
Old Nov 19, 2010 | 02:17 PM
  #48
H4RDCOR3's Avatar
I just ordered a boost solenoid, the bracket and the lines with the pills. It should all be here thursday...i dont have the pills in there now. So its all good hopefully ill let yall know how things turn out
Theres your answer. WG actuator is good and there were no pills in the lines. That should most likely take care of your issue.
Old Nov 19, 2010 | 03:29 PM
  #49
talonesi95t's Avatar
Originally Posted by sparky
talonesi95t Are you running a MBC, or still running the factory boost control scenario?
no mbc, when i got the car it had a blown evo8 turbo and the vac lines were T'ed in two different places. so i bought a stock evo9 put it in and redid the vac lines accorinding to the diagram decal on the hood. but the vac lines i used are not stock, so i think im going to buy them since i read they make a difference. but when i saw my car hitting 25+ psi, i was like not good. so i asked around localy, i got an i idea to just run the vac line from the j-pipe nipple to the wastegate, when i have it this way i only get 10 psi.
Old Nov 29, 2010 | 02:47 PM
  #50
Alright, bringing this one back from the dead, i just got all my parts in and glad to say the Evo is back in action. full boost and alot more fun than when i first got it.
Thanks to everyone that helped me out on this one.
So people know i replaced the boost solenoid and the vaccum lines(with boost pills) and its back to normal.
Old Nov 29, 2010 | 02:56 PM
  #51
Boosted Tuning's Avatar
Glad to hear it worked out for you.
Old Nov 29, 2010 | 07:45 PM
  #52
4RETECH's Avatar
Congrats! Enjoy
Old Dec 2, 2010 | 10:18 PM
  #53
Ok one more problem, i still have my boost, but it is only at around 15-18 sometimes it will get close to 20, from low rpms all the way to high, and sometimes not all the time if i floor it from 2nd, i will get one small studder, then nothing. It did it bad (check engine light bad) when i had other plugs in it so i switched back to the original plugs, do you think it still is a bad plug? It only does it every once and a while. And its like one lil hiccup then nothing.
Old Dec 3, 2010 | 01:27 AM
  #54
Force 6's Avatar
tune or check all hoses are clipped
buy some now aftermarket hoses and see how
