Major WTF is going on thread!!!!
Old Nov 17, 2010 | 07:55 AM
EvoVIIIFL's Avatar
Originally Posted by murderedevo256
I did try the old coils and still no spark or anything. I do have injectors but just for start up and getting itrunning it should still run halfway decent
No spark at all? Did you check all the grounds?
Old Nov 17, 2010 | 07:56 AM
n2oiroc's Avatar
were there any engine grounds disturbed with all the wrenching?
edit: ^beat me to it!^
Old Nov 17, 2010 | 08:02 AM
murderedevo256's Avatar
Yeah we did a few times it sounds like that or timing is off sort of that kind of missing. Its very aggravating sometimes!lol
Old Nov 17, 2010 | 08:04 AM
All the grounds were not touched and the all look nice to me unless when somethings just not hooked up but it ran fine a few hours before
Old Nov 17, 2010 | 08:12 AM
n2oiroc's Avatar
the terminals where they attach to the battery are known to crack. take a close look at them.
Old Nov 17, 2010 | 08:14 AM
L@Ncer06's Avatar
its the plugs
Old Nov 17, 2010 | 08:24 AM
n2oiroc's Avatar
did you go over all the fuses?
Old Nov 17, 2010 | 09:34 AM
All fuses look good, and a fresh set of plugs is going in later. Hopefully it will help
Old Nov 17, 2010 | 09:47 AM
06MRV8Killer's Avatar
Interesting, I would like to see what the culprit is (everything I could think of has been mentioned)... bump for you for some help.
Old Nov 17, 2010 | 09:57 AM
m4tt VIII's Avatar
I also did major modifications to my car and the first couple times it started things "seemed" to work, then I couldn't get it to start unless I gave it gas, then it wouldn't start at all. Make sure nothing has water in it, (FMIC, Intake, etc...).
I had a similar problem and there were a number of culprits. My plugs were bad (replaced with new ones), my MAF was bad (I replaced it with a new one) and it was throwing a code.
I brought my car to AMS and they straightened everything out for me.
Old Nov 17, 2010 | 06:31 PM
Not throwing any codes still but put new plugs in and it runs now but still missing like crazy?????
Old Nov 17, 2010 | 07:22 PM
Its throwing tons of fuel out for some reason and backfires alot. It also sometimes will hit my 2step at timesbut also will just go past it sometimes and it never goes past 6k unless im moving. Don't get worried im not just reving it like crazy im just trying to get things figured out.
Old Nov 18, 2010 | 08:10 AM
bump for any suggestions??? No cel but can anyone think of something that might be causing this?
Old Nov 18, 2010 | 08:16 AM
milford's Avatar
be over in a few....a title change may be in the near future.." PA FULL PART OUT" ? haha
Old Nov 18, 2010 | 08:36 AM
delcster27's Avatar
What r the current symptoms?
