Major WTF is going on thread!!!!
Old Nov 18, 2010 | 08:39 AM
  #31
murderedevo256's Avatar
lol thanks. Well its running like complete crud missing still. and until it warms up I have to keep giving it gas
Old Nov 18, 2010 | 08:43 AM
  #32
delcster27's Avatar
Is it an actual miss or just sound like it? Also does it go away or still happen when its warm?
Old Nov 18, 2010 | 09:25 AM
  #33
Yeah its a bad miss and wont idle. When it gets warm it clears up and will idle somewhat
Old Nov 18, 2010 | 09:33 AM
  #34
L@Ncer06's Avatar
what gap do you have the plugs at also did you check to see if there all fireing?
Old Nov 18, 2010 | 09:34 AM
  #35
delcster27's Avatar
Have u checked the iac? I know that has nothing to do with no spark but my car acted like this and it was the culprit...r u still on the stock ecu?
Old Nov 18, 2010 | 09:50 AM
  #36
I checked it but never touched it before. I was getting p0122 for my tps but its gone now and now im getting code p0500 for vehicle speed sensor???? Also how should I have my boost lines hooked up from ic pip to the 2 fitting on the wastegate
Old Nov 18, 2010 | 10:04 AM
  #37
delcster27's Avatar
My iac valve went bad in a matter of 30 minutes no signs before...i will have to look at mine when i get home i can't remember off the top of my head
Old Nov 18, 2010 | 10:56 AM
  #38
My idle air control isn't showing a cel though. And would it cause a missfire
Old Nov 18, 2010 | 11:05 AM
  #39
gsrboi80's Avatar
What are you using for boost control??
MBC will have an input and output Input comes in from compressor housing/LICP/etc.. Out put goes to the WG use the lower barb on the WG for a MBC.
This should not effect the car idling and such unless as mentioned earlier unless there was a bad boost leak
Old Nov 18, 2010 | 11:33 AM
  #40
Yeah I have a halman hooked up correct.
Old Nov 18, 2010 | 01:03 PM
  #41
delcster27's Avatar
IAC won't show a code and it doesn't cause a misfire just misfire symptoms. Like i had to keep hitting the gas to keep the car running at idle and while driving it wouldn't go over 6k. It sounds like the things that cause misfires you have checked already. My ECU fried a cylinder in between timing the car and putting it on the dyno.
Old Nov 18, 2010 | 04:40 PM
  #42
Maf was too close to turbo cause we put an intake on it and it runs really good. Now it just doesn't idle whenit warms up. What could cause that maybe iac?
Old Nov 18, 2010 | 05:40 PM
  #43
gsrboi80's Avatar
At this point may just be something that can be worked out with tuning. Flow of the bigger turbo was likely screwing the MAF signals. Make sense that you moved it further from the inlet and it's running better now.
I say drop the bigger injectors in with Scaling and Latencies that are close, then tune it out from there man.
Not too far away if you ever need a hand bro
Old Nov 18, 2010 | 06:11 PM
  #44
Fast_Freddie's Avatar
Veteran: Navy
This definitely seems tune related, and if the 2 step isn't working correctly seems to me that it may be a corrupt ROM. I would try a completely new rom (porting over all current setings) and see if that fixes the problem...
Old Nov 18, 2010 | 07:14 PM
  #45
Problems solved. Intake cleared everything up once the intake was put in and adjusted to screw on tb a little to hold me over till my tune soon. Fresh set of plugs too
