Help...Installing Oil Pressure/Temp Gauges
Old Nov 20, 2010 | 11:06 AM
mx4life85's Avatar
So I've decided I finally want to do the radio relocation and have the 3 52MM gauges where the OEM Radio goes. (by using the Gruppe-S 3-Gauge Panel)
When picking out gauges to fill the 3 spots, I chose to add an oil temp and pressure gauge.
Now on to the questions...
The gauges I ordered were Prosport 52MM Electrical Temp/Pressure, with the additional ProSport Oil Adaptor Plate .
I was planning on just hooking everything up to the adaptor plate, but after further reading I read that the oil pressure or temp sensor (can't remember which one) can break and fail prematurely due to the engine vibration at high RPMs. These gauges will just be used for DD and spirited driving, but no track use and really beating the snot out of it. That being said, should I also purchase this AMS Remote Oil Pressure Sending Unit, or will I be fine without it?
Old Nov 20, 2010 | 11:19 AM
EvoJoeIX's Avatar
you will be fine just running the oil filter sandwhich plate.... if you really want/need the piece of mind just buy the line
Old Nov 20, 2010 | 11:21 AM
mx4life85's Avatar
Ya I just don't want it to break 2-3 months after installing it and then have to mess with it again.
I'm a college student and can only work on my vehicle when I'm home; so that makes things quite an inconvenience.
Old Nov 20, 2010 | 11:24 AM
EvoJoeIX's Avatar
hey man i understand. its your car. and the line is only 35 bucks. i say just get the line so your worries are gone
Old Nov 20, 2010 | 11:30 AM
mx4life85's Avatar
True...thanks for your input I'm going to get a little more information and see what other people's reactions are to this thread and then decide.
Old Nov 20, 2010 | 11:56 AM
evo8426's Avatar
I plan on getting the line when I buy my gauges. I don't want to have to replace it once I put it in. You might as well order me one while you're at it
Old Nov 20, 2010 | 01:07 PM
Bobster22388's Avatar
I bought that line and it actually worked out great, brings the sending unit up further in the engine bay to make it really easy to run the wires needed to it and more mounting places
Old Nov 20, 2010 | 01:30 PM
mx4life85's Avatar
Cool could you post pictures of your line mounted?
Also, the line is needed for the temperature sensor or pressure sensor?
Old Nov 20, 2010 | 01:57 PM
EvoJoeIX's Avatar
line is needed for pressure sender
