fp red or cams and the stock turbo
Old Nov 24, 2010 | 04:44 PM
  #31
Frew's Avatar
I understand, Im a newb when it comes to cams, with my last platform there were very few cam options, and the few that were out there require solid lifters due to the stock lifter being over extended from the cams having a smaller then stock base circle since they were regrinds
Old Nov 24, 2010 | 05:10 PM
  #32
EvoJoeIX's Avatar
you dont need anything with gsc s2's except the beehive springs......
s2's are easily one of the best cams out there for an evo. bottom line!
Old Nov 25, 2010 | 11:57 AM
  #33
Frew's Avatar
That's what I have been reading, and the springs are very cheap, nearly half the price of supertechs for my old plateform
Old Nov 25, 2010 | 10:31 PM
  #34
Graphic's Avatar
Originally Posted by henrys
Being used to V8's and turbo diesels I already think the stock IX turbo is a bit laggy. I'd go with cams. However, check the cam test thread to see the difference between all of them:
https://www.evolutionm.net/forums/ev...-cam-test.html
That cam test is out dated.
Old Nov 25, 2010 | 10:48 PM
  #35
AWD Motorsports's Avatar
Red
Old Nov 26, 2010 | 02:48 AM
  #36
Z-Ball's Avatar
fp red will be most efficient when cams are in.... get cams and valvesprings to rev higher and to get the most out of a fp red turbo..... oh and injectors......oh and a tune..... oh and meth injection.... oh and a intercooler and piping.... oh and exhaust... oh and intake.... oh so many things the list goes on.....
Old Nov 26, 2010 | 07:32 AM
  #37
Jerm__'s Avatar
If this guy is planning on keeping this car for the street, and under 450whp, why does he need the FP red? I would get the FP Green which have been proven to make over 400whp and will have a smaller price tag than said turbo's above and will have less turbo lag....its win/win.
Old Nov 26, 2010 | 08:35 AM
  #38
Frew's Avatar
I will have to look into this, I just dont want my force inducer to limit my power potential like my last project, I went with to small of a blower and it hurt me in the end, also what size injectors are needs with cams and a red/green?
Old Nov 26, 2010 | 08:38 AM
  #39
Frew's Avatar
also why are the fp red and fp black the same price for the IX?
Old Nov 26, 2010 | 09:04 AM
  #40
Frew's Avatar
also I saw something about about having to use a larger oil line when you use a red, any truth to this?
Old Nov 26, 2010 | 09:05 AM
  #41
Because they require the same parts to build just different sizes..
Mike
Old Nov 26, 2010 | 09:12 AM
  #42
cij911's Avatar
Originally Posted by 3dcalixpress
yes theres also a guy in so cal with stock cams and fpgreen doing mid 400whp numbers on e85 ( i think )......
so you should consider what type of reliability you are after.low power/great spool or high power with a slight higher spool.more stress on parts with more power.so reliability/drivability is key...
I am on a stock block, stock head, stock cams, and FP HTA Green + 91 oct + meth and water combo and am at 440 whp +....I have a very broad power curve and the car is a blast to drive on the street.
I would recommend the HTA Green to anyone wanting to make 400 - 500 whp with a broad power band.
Old Nov 26, 2010 | 09:09 PM
  #43
Frew's Avatar
are there different versions of the fp green?
Old Nov 26, 2010 | 09:29 PM
  #44
Frew's Avatar
also, I don't plan on running water and methanol, I have ran it on my previous vehicles and in the past the gains have been great but the hassle of running it day to day is not worth it to me.
Old Nov 26, 2010 | 09:38 PM
  #45
3dcalixpress's Avatar
the guy i seen has a rr evo9 .i noticed you have gg..he has similar setup to you.i think he works at snyapse or something...
