Torn Coolant line ?????
Old Feb 2, 2011 | 12:33 PM
white_evo27's Avatar
heres some pics of what is capped off... you can see both caps with white zip ties around them in pic 2 and 3... are those the 2 that i am supposed to loop? plus does it look like my throttle body is upside down in pic 1?
Old Feb 2, 2011 | 12:59 PM
bump... please help i keep blowing the top cap off and losing a massive amount of coolant! this is my DD and i need it running! thanks guys!
Old Feb 2, 2011 | 03:43 PM
bump anyone?
Old Feb 2, 2011 | 03:58 PM
Stock-ish's Avatar
Originally Posted by rcgoff2
All,
On my way to work this morning after the car came to temperature I mad a 1st and 2nd gear pull. About 20s later, I saw smoke coming from the hood of my car = (
I shut her down and popped the hood to see antifreeze all over the engine bay and started looking for the leak. Their is a 7-8 inch long rubber line that runs from a port off the top back right corner of the block, and into a connection near the throttle body. The line is about a half to 3/4 " dia. and I saw a 1 " tear in the line near the connection on the block.
My question is, has this happened to anyone else before or is their a known cause for this problem? Background: My car made 330 AWHP on the Buschur dyno, has 90k on it cams and other mild bolt ons. I changed the plugs yesterday with NGK Br7es and replaced the battery 10 days ago.
Any advice or input would be greatly appreciated.
-Ryan
while your at it change the line from the thermostat housing to the turbo. i had a leak there and it was hard to find.
Old Feb 2, 2011 | 04:03 PM
bump for adding to a 3 month problem... any ideas on my problem?
Old Feb 2, 2011 | 04:57 PM
Stock-ish's Avatar
i would try running the lines to the factory setup, im not sure how to runs the lines modified.
Old Feb 2, 2011 | 05:06 PM
Evoryder's Avatar
your radiator cap is popping off? You got too much pressure in your cooling system. Head gasket is probably done. Hose tend to rip and tear when head gasket goes.
Old Feb 2, 2011 | 05:09 PM
no the vacuum cap in the pic keeps popping off, im just wondering if i can run a hose to both caps to loop it... since the TB lines are already capped off..
Old Feb 2, 2011 | 05:32 PM
Evoryder's Avatar
i just looped the two hoses with fuel line. 1ft of fuel line plus 2 clamps. all done.
Old Feb 2, 2011 | 05:33 PM
awesome thats what i was asking, those are the 2 spots to loop the line though right! you saved my night right now if it is!!!
Old Feb 2, 2011 | 06:17 PM
EvO9 PiPER's Avatar
I am not sure what those lines are that have caps on them but I'm pretty sure those aren't the 2 lines everyone is telling you to loop.
The 2 lines are (looking at the back of the block from the firewall) will be on the top left corner. There will be two ports coming out on top of each other with an inch or 2 of space between them
Old Feb 2, 2011 | 08:50 PM
Evoryder's Avatar
the 2 nipples shown are feed and return for the throttle body.
I dont have coolant running through my tb, therefore i have my tb nipples capped off. The two nipples show are looped in my case and can be looped for others. THe fluid travels in same direction anyways; feed >return to radiator
Old Feb 2, 2011 | 09:49 PM
awesome thanks man thats the answer i was looking for!
going to loop this right now... i think the pressure of the coolant is the reason the nipple kept blowing off
Old Jun 13, 2011 | 04:49 PM
elDuderino's Avatar
Thumbs up ohh, word.
noob here, just wanted to say thanks. ran into this same problem just a few days ago and this thread was spot on!
that is all
Old Jun 13, 2011 | 05:17 PM
Evoryder's Avatar
Oh. The Tb in this page is installed upside down.
Nothing like a useful thread !!
fostytou
359
Oct 23, 2025 09:54 AM
Raceghost
Mar 11, 2019 01:04 PM
Dstorm7
Lancer Troubleshooting
Sep 24, 2015 09:37 PM
han74j
Sep 23, 2014 03:37 PM
llDemonll
May 17, 2012 06:00 PM
