high idle on stock 9
Old Nov 30, 2010 | 11:31 PM
mike-237's Avatar
i thought i had this problem solved yesterday after replacing the ISC (used) (before it used to stutter when the a/c was turned on) now when i let it cool down for a few hours my idle will hold between 1,500 an 2,000... but heres the thing this will only happen until i actually start moving for about a minute the you can feel the high idle then no matter how many times u stop its fine at 1,000rpm, and the car is 100% stock
pleases help... new evo owner
Old Dec 1, 2010 | 12:06 AM
twabtoxer's Avatar
hhmmm did you check to make sure that the throttle cable wasnt too tight. make sure it has some slack that way it closes all the way
Old Dec 1, 2010 | 12:41 AM
mike-237's Avatar
Yup I tried that first.. And as we speak I'm heading out to swap out the sensor and when I put it in neutral while moving my idle bounces between 1,800 and 1,500
Old Dec 1, 2010 | 06:51 AM
AboodsEvo's Avatar
So when the engine warms up does it idle lower to stock 850-950 rpm range??
Old Dec 1, 2010 | 06:52 AM
AboodsEvo's Avatar
hah sorry for the double post lol
Old Dec 1, 2010 | 06:55 AM
boosted91t's Avatar
The car is going to idle higher until it is warm. Nothing out of the ordinary
Old Dec 2, 2010 | 12:39 AM
mike-237's Avatar
Eventually it drops to just over 1k 1050 most probably but never less than that
Old Dec 2, 2010 | 11:21 AM
Earthen's Avatar
This is normal, it is called "high idle". It will idle high to warm up faster. After running the car for a bit it will idle at a normal rpm.
browningderek
AEM EMS
73
Mar 2, 2019 08:35 PM
9!'clipseDOHC
Jan 9, 2016 10:21 PM
hiboost2.0
16
Jan 2, 2014 08:10 AM
bsh
Jul 30, 2012 11:34 AM
FINCHY78
Cobb AccessPORT
Jun 12, 2012 12:30 PM
