Fp Red Internal Wastegate
Old Dec 2, 2010 | 07:26 AM
GBAILEY472's Avatar
I was told that my internal wastegate is to small to hold up 30 psi
( W/meth ) and its causing air to go back in the turbo causing a vibration in the piping.
Also can you tap out the insert that splits in the middle to make the whole bigger ????
Thanks in advance
Old Dec 2, 2010 | 08:05 AM
Andrewkbmx's Avatar
get a stonger wastegate
Old Dec 2, 2010 | 08:16 AM
4xforce's Avatar
Fp sells a 25psi wastegate actuator but many people do fine with the 18psi unit. If you run near 25psi or more on a regular basis then just get the 25psi unit. You could also get that hotside ported but no need for an external wastegate. I would cover all your other bases first. It's likely something else maybe going on.
Old Dec 2, 2010 | 08:38 AM
sk8terdude929's Avatar
i have a FP 18psi on my green and run 29psi daily with no problems. holds 29psi all the way to redline.
Old Dec 2, 2010 | 03:56 PM
EVO8emUp's Avatar
An internal WG that is too small would do the exact opposite of not produce enough boost.
A "stronger waste gate" makes no sense, however a "stronger waste gate actuator"
does.
Sounds like you need a WG actuator with a stiffer spring, assuming everything else is okay.
Old Dec 2, 2010 | 04:11 PM
benselements41's Avatar
Deffinitvly sounds like a stronger wastegate will fix your problems!
Old Dec 2, 2010 | 06:28 PM
Evolutionn's Avatar
this
GBAILEY472
Apr 4, 2016 01:47 PM
GBAILEY472
For Sale - Wheels / Tires
Apr 15, 2013 06:28 AM
EvokidIX
Jan 13, 2013 10:27 AM
GBAILEY472
Oct 24, 2012 12:08 PM
Fknfstevo
Jun 23, 2011 07:32 PM
