Idle causing me a headache!
Old Dec 7, 2010 | 12:27 PM
bhood1's Avatar
Ok, so I start the car and when its cold it has a normal idle. after the car warms up, the idle sits at 2k. Has anyone else had this issue? How do I fix it?
Old Dec 7, 2010 | 02:05 PM
sunrichmond's Avatar
iacv
Old Dec 8, 2010 | 07:31 AM
HaVoC187's Avatar
Try this
Start the car and take it for a spin until it is completely warmed up.
Turn the car off and disconnect the negative battery terminal for about 2 min to reset the ecu.Reconnect the battery terminal and start the car.
Now since your engine is warm the idle should settle right away.
Take a screwdriver and adjust the biss screw that is located on top off your throttle body(you can see it between the "legs" of the strut bar).
Adjust this until you reach the desired rpm and then let the car idle for 10 min.
Turn the car off and back on and see if this fixes the problem.
Old Dec 8, 2010 | 07:37 AM
MuslimEvoFreak's Avatar
Originally Posted by HaVoC187
Try this
This is not recommended since it throws off the iacv. If you touch that biss screw you will need to re-tune.
Old Dec 8, 2010 | 07:38 AM
rawkus's Avatar
Adjusting the BISS screw as mentioned above is BAD ADVICE. You should not adjust the BISS screw unless you have initiated the actuator within EvoScan or the factory MUT II or III. If you don't know how to do this then leave that alone for the time being.
I'd check the simple stuff like vacuum/boost leak, clean the throttle body and ensure your cooling system is properly bled (this can cause funky stuff if coolant isn't reaching certain temp sensors).
Dan
Old Dec 8, 2010 | 08:32 AM
Mr.X's Avatar
Dan
+1
Old Dec 8, 2010 | 08:35 AM
bhood1's Avatar
I have checked all the vacuum lines and they are good. The coolant idea isn't bad though, I will flush my system and clean my throttle body and see if that helps.
Old Dec 8, 2010 | 08:44 AM
Y.O.EVO8's Avatar
Try adjusting the tps
Old Dec 8, 2010 | 08:49 AM
05blue8's Avatar
Can you log in evoscan? If so it should tell you what your TPS is set at...that will help. You can also test your IACV if you want by unscrewing it from the throttle body with the car off and leaving the electrical plug connected. Pull it out, make sure the O-ring is in good shape. While holding it have someone turn the car to on, watch the IACV and make sure it moves in and out and clicks, if so it should be good, if not, it's bad
Old Dec 8, 2010 | 09:19 AM
suicidevo's Avatar
tell me what fixes the problem cause im having simular problems.
Old Dec 10, 2010 | 07:48 AM
bhood1's Avatar
Well, got the iacv ordered. Took my off and it doesn't move at all when I turn the key over. Can anyone tell me how to adjust the tps just in case this doesn't work?
Old Dec 10, 2010 | 10:45 AM
rob328's Avatar
if you don't mind me asking , from where you ordered? I believe i might have to order one too.
Thanks
Old Dec 10, 2010 | 01:28 PM
grayw's Avatar
You will still need Evoscan or a MUT tool to adjust the ICV as already posted above. Easy to see if the ICV is working correctly with a quick log, just see if it's between 20 and 50 steps on warm idle.
To set the TPS, the output voltage should be 0.68v to 0.72v base setting with the ignition on.
Old Dec 10, 2010 | 02:44 PM
bhood1's Avatar
Thanks
Got it from here
http://www.mitsubishiparts.net/catal...ction=690#2058
Old Dec 10, 2010 | 02:45 PM
bhood1's Avatar
I have evoscan. Waiting on my tatrix cable to come in.
