Possibly dumb...but how do you remove the Mivec cam gear
Old Dec 9, 2010 | 09:38 AM
Svendiesel's Avatar
Just want to be 100% sure that it IS in fact removed from the cam by removing just the allen bolt in the center of the gear.
Old Dec 9, 2010 | 11:06 AM
mkcolgan's Avatar
the only other way i could imagine the gear coming off is with the entire cam coming out... so yeah its the center bolt that takes the gear off
Old Dec 9, 2010 | 11:52 AM
adam_79_2005's Avatar
It was a b!tch to take off, I ended up stripping mine and having to take it to a shop, but it's a 14mm Allen size, I went all over the place looking for a tool, even sears didn't have one, probably the only thing I really dislike about the Mitsubishi
Old Dec 9, 2010 | 05:27 PM
srtboostin22's Avatar
the allen bolt does NOT remove the whole cam gear.. fyi
Old Dec 9, 2010 | 05:42 PM
Roadrunr's Avatar
If you are talking about the Exhaust Cam on a 2006 IX. Their is a 14 mm allen made of aluminum that must be removed first. Under the plug you will find the bolt that holds the cam gear on.
Don
Old Dec 9, 2010 | 05:52 PM
naplesevo's Avatar
if you are asking this you should not be doing it !
Old Dec 10, 2010 | 03:55 PM
Svendiesel's Avatar
Hey Nipplesevo, I didnt ask your opinion on whether or not I should be doing something or not. I asked a simple question. I did it right by confirming first the right way to do it, versus other people just jumping into something without knowing. Theres several sets of bolts on the mivec cam gear, I always double check before doing something.
And yes the 14mm allen is just a plug and then the bolt is underneath. It was straight forward, to those of you who helped thanks for not being a tool.
Old Dec 10, 2010 | 04:01 PM
MicRX's Avatar
Hahahaha +1 people just can't help themselves sometimes, always measure twice and cut once, you asked a great question which seems alot of people have had problems with
Old Dec 10, 2010 | 05:42 PM
Playap07's Avatar
Veteran: Air Force
hehehe he told you naples!
Are you putting in something different in its place or just disableing it?
Old Dec 10, 2010 | 09:21 PM
word brother, **** if i had a dollar everytime i was tearing apart something in my i had no idea about i would have at least a morgage payment knocked out, the only thing i do is make sure i use a sharpy and masking tape to make sure i can retrace my steps to put it back toether.
How else are you going to learn?
Old Dec 10, 2010 | 10:43 PM
Svendiesel's Avatar
My Evo's apart right now and the cam gears and sensors were left on my old cams while they were out of the head.
I bought S3 cams because I was upgrading from S2's, and I just sold the S2's the other day so I was taking the sensors and gears off so I could ship the cams to the buyer.
Old Dec 11, 2010 | 01:40 PM
Spoolin4g63's Avatar
your gonna have to get 14mm allen key off snap on or matco.
Old May 25, 2011 | 03:51 PM
EGbeater's Avatar
Actually, you can get it from amazon.com for only $9.73 (plus free shipping, if you buy another $15-worth of stuff that qualifies for Super Saver Shipping):
http://www.amazon.com/GearWrench-806.../dp/B003DZ0PI6
Sure, the Gearwrench 14mm allen socket is made in Taiwan, and isn't exactly the same quality as the equivalent part off the Snap On, Matco, or Mac tool truck. But for someone like me who's likely to use it all of 2 or 3 times in a lifetime, it's perfectly fine. The cap on the MIVEC gear is aluminum anyway, and that oil plug is more likely to strip and need to be replaced before the allen socket is going to show any wear.
Also, just FYI: don't lose that unique washer with the integrated rubber seal that sits under the MIVEC plug. It's part #MD623114, and it's SEVEN DOLLARS. Guess how I know.
Old May 25, 2011 | 06:41 PM
sessanator18's Avatar
I used the head of a bolt with two nuts backed into each othernthen just franked on it
Old May 26, 2011 | 08:34 AM
EGbeater's Avatar
That's actually not a bad idea, if you've got nothing else... good improvisation!
