Everyone read this!!
Old Dec 12, 2010 | 10:00 PM
  #46
NickYubaCity's Avatar
This is great info; I'll make sure to check mine after my intercooler and piping upgrade next weekend, and before any future tuning. Thank you to everyone that contributed useful information.
Old Dec 12, 2010 | 10:04 PM
  #47
Raptord's Avatar
Originally Posted by 4RETECH
Here is my travel set-up when not working on cars at my garage or shop.
Air tank, hose, in-line air regulator, spray bottle with soapy water, adapter made from home depot racing
https://www.evolutionm.net/forums/ev...er-5-02-a.html
Remember when testing, use the soapy water because you can't hear boost leaks unless they are big.
Don't have an air tank either. At the risk of sounding like a total nub, would a simple bicycle pump be useable?
Old Dec 12, 2010 | 10:05 PM
  #48
TommiM's Avatar
Originally Posted by Go_Lancer_Go
someone should create a youtube video on boost leak testing
also how do u guys check the IC endtanks on a evo 9 w/o removing the bumper?
There is a write up on here I believe. If its anything like the evo 8 bumper, the front bumper comes off easily in 10 minutes if your taking your time. Its only a few bolts and some plastic panel screws. One thing I do is zip tie my oil dipstick tube just in case it decides to pop off during a boost leak test, and leave the car in neutral with the parking brake, not in gear. I actually had enough pressure in the system to want it to turn the engine over and the car wanted to creep forward on me. Otherwise its pretty straightforward.
Old Dec 13, 2010 | 01:02 AM
  #49
freezingcoffee's Avatar
Wow, this is very helpful. Thanks!
Old Dec 13, 2010 | 04:36 AM
  #50
4RETECH's Avatar
I have never used one, but some people here do. I think a pump might not hold enough air to keep the system pressurized unless you can spray and pump, spray and pump.
Old Dec 13, 2010 | 07:39 AM
  #51
CBRD's Avatar
Also-
ANOTHER important note,
use soapy water between tbolt clamps and the coupler you have them installed on! That helps the clamp to slide under itself easier when you tighten it, and will prevent pinching of the coupler!!
To check the IC inlets and outlets is enough with a pressure test to hear a leak, sometimes if the undertray is on, you can remove that by itself to fix it, makes it easier when the clamps are in the right orientation so that you can get to them without removing the bumper!
cb
Old Dec 13, 2010 | 07:47 AM
  #52
TURBevO8's Avatar
I always boost leak test my car after messing with anything with a bottle of soapy water and air hooked up to the turbo. But before a tune, I let the pros look it over. Nice to know CBRD is so thorough as they are doing my next tune.
Old Dec 13, 2010 | 07:57 AM
  #53
kousayee's Avatar
Boost leak test with every oil change !!! Now that is a good habit
Old Dec 13, 2010 | 09:35 AM
  #54
TxEvo8's Avatar
Yes it will work, but you will have to get a friend to do the pumping while you use the soapy water to hunt down leaks..
Old Dec 13, 2010 | 10:31 AM
  #55
sk8terdude929's Avatar
Originally Posted by EJEvo
Same issue as yours. According to the Cobb article referred to in the first post, you could use a bicycle valve instead of a compressor valve. I have a tire compressor that I figure I could use, just need to figure out where to get a proper valve and install it in the pipe cap.
I need to do this because my new CBRD BBK Full turbo set up went south (bad idle/stumble/stalling) about a week after they installed it, and being I'm about 6 hrs away from them, I need to do the troubleshooting myself. CBRD did find a leak in my TB and fixed it during the install - no one had found that one previously. I had MIL.SPEC rebuild that TB and when it came back with new shaft seals I had to turn down my boost since I no longer needed to compensate for the leaks there. Word to the wise - if your TB is 4 yrs old or older and is using the OEM shaft seals, I guarantee they're leaking.
you can get a tire valve from any auto place that sells tires, should only be 1-2$ and get a PVC cap from sears or home depot. i made mine for less then 10$ even has a tire psi gauge i got from autozone on it.
Old Dec 15, 2010 | 10:59 AM
  #56
OverBoostedEvo's Avatar
lol, i did a boost leak test on my car thought everything was perfect and even told Chad i did but had him check anyway before he tuned me and he found leaks that i didnt hahaha, so def have a shop do it. better yet just take it to CBRD!!!
Old Dec 15, 2010 | 11:08 AM
  #57
CBRD's Avatar
we just had to put tbody seals in a car with 15,000 miles
if they weren't done... do them!
cb
Old Dec 15, 2010 | 01:49 PM
  #58
Will Urlacher's Avatar
for all you do it yourselfers out there:
http://www.youtube.com/watch?v=u3Kqh52PC6Q
Old Dec 15, 2010 | 02:04 PM
  #59
EvoJoeIX's Avatar
make sure you use some kind of glue when securing the pvc cap to the hose. they willl pop off if you dont.
we put a good size hole in my buddies finger when the cap blew off of mine.
wenjie1812
Sep 17, 2016 06:17 PM
DeatschWerks
Jul 31, 2012 03:23 PM
CBRD
39
Feb 9, 2012 09:53 AM
ETS Michael
33
Feb 24, 2010 08:47 AM
Ted B
Feb 17, 2010 08:52 PM
