aem wideband wires cut
Subscribe
Dec 10, 2010 | 11:13 AM
So the wires to my aem wideband got cut by my alternator. It got cut before the sensor connector so I can't just get a new sensor....
my question is can I just use connectors and connect the wires together? I'm not sure how sensitive the wideband sensor is and I don't want a wideband that's not accurate because that's just worthless.
Reply 0
Dec 10, 2010 | 11:24 AM
Just reconnect the wires...it makes no difference unless the wire was actually bad.
Reply 0
Dec 10, 2010 | 01:12 PM
Just solder them together. Should be good to go.
Reply 0
Dec 10, 2010 | 01:15 PM
okay i thought so
im gonna solder them tonight, and i guess ill know if the gauge is thrown off any when i get tuned
Reply 0
Dec 10, 2010 | 01:21 PM
It should not effect the outcome of the reading from the sensor. Just make sure your soldering connections are solid and the wires are correctly insulated. All the sensitivity is in the sensor.
Reply 0
Dec 10, 2010 | 02:05 PM
Use flux and clean the connection good, I am a electronics tech so I can tell you flux is going to make a big difference, it cleans the joint and helps the solder flow a lot better.
Reply 0
Dec 11, 2010 | 12:29 PM
Solder and heat shrink. I agree with the use of flux and staight solder. The solder that requires no flux tends to leave residue behind.
Reply 0
Dec 11, 2010 | 01:37 PM
just solder them back together, shrink wrap them and you'll be fine.
Reply 0
Dec 11, 2010 | 03:37 PM
i soldered and shrink wrapped them.... still doesnt work. the wires were definately cut so im not sure what else could be the problem
all i get is the "---" on the gauge
Reply 0
Dec 11, 2010 | 05:10 PM
Quote: i soldered and shrink wrapped them.... still doesnt work. the wires were definately cut
Since your wires were cut and you didn't unplug the o2 sensor from the bung, you probably damaged the sensor. The o2 sensor needs to be powered when hot exhaust gases flow from the engine. It says this on all wideband instruction manuals.
Reply 0
Dec 11, 2010 | 05:24 PM
yea i seen that when i was going through my manual.
im gonna test the sensor tomorrow and see what happens
Reply 0
Dec 12, 2010 | 01:04 PM
Joe I think I have tried to help you in 2 threads this past week, so if you are ever down my way, I need to get a ride in that thing.
Reply 0
Dec 12, 2010 | 02:12 PM
Haha funny thing is I might be moving to south carolina soon
Reply 0
Dec 12, 2010 | 05:21 PM
Quote: Haha funny thing is I might be moving to south carolina soon
Which part? Did you figure out if the sensor is bad?
Reply 0
Dec 12, 2010 | 05:39 PM
north charleston
and no i didnt get a chance to check my sensor today
im sure its def the sensor, as i was driving around last night it would want to read a little bit, then it would just goto the "---".... but even when there was numbers on it, they were way off
Reply 0
Subscribe
