weird misfire or fuel problem?
Old Dec 16, 2010 | 04:27 PM
kmevo3's Avatar
hmm any easy way to check for a leak?
Old Dec 16, 2010 | 04:42 PM
blackevolution8's Avatar
Originally Posted by kmevo3
so even completly stock evos right off the showroom floor will do this? thats odd
Is yours bone stock? Its usually lightly modded evo's that free up some power restrictions and put you into higher load cells. You'll need to boost leak test it. A coupler that connects to the intake of the the turbo and apply compressed air until you hear it hissing out of the leaking spots. Fix leaks and repeat until you dont hear any hissing... up to about 25-30 psi.
Old Dec 16, 2010 | 06:39 PM
kmevo3's Avatar
it has a 3 inch bushur turbo back a stainless 02 dump and a lower ic pipe thats it as far as i can see not sure if it has ever been tuned before. but i put in a boost gauge and it spikes 21 holds 17psi.
Old Dec 16, 2010 | 06:47 PM
tscompusa2's Avatar
needs tuned, thats all.. theres nothing wrong with it. i can convert you to v7 maps for dirt cheap if you have the neccessary hardware for it. wideband, tactrix cable, etc.
if not give me the rom ill remove the boost cut and you can be on your way. free
Old Dec 16, 2010 | 08:03 PM
kmevo3's Avatar
im gonna get a few things like the wideband, i wanna just throw a ets filter kit on it and then get it tuned...
Smogrunner
Jun 26, 2017 03:54 PM
IraqFire88
12
Oct 16, 2011 08:44 AM
PattonX
10
Feb 21, 2010 10:56 AM
BlueEvo61106
Oct 30, 2008 09:50 AM
worksevo89
18
Sep 7, 2008 03:56 PM
