Zeitronix Zt-2 Kit
Old Dec 18, 2010 | 08:25 PM
Brsox10288's Avatar
Originally Posted by Thrilla
Go with the guage, it's a cleaner look IMO. I have it set to boost and AFR.
The LCD screen gives you more information, except it's hard to find a good place to install it and look clean.
I really am leaning more towards to Gauge because it does look much cleaner. The only problem is that I wanted to get the Center Console 3 Gauge Pod and relocate the radio to the buddy whole. This one gauge does so many things so I would have two empty spots. I dont want to put my gauges anywhere else cause it just looks tacky.
Old Dec 19, 2010 | 10:01 AM
limp_noodle's Avatar
Originally Posted by 4xforce
Easy setup and works flawlessly. I would opt for the ZR-2 gauge instead of the LCD. I found the LCD hard to quick reference. Otherwise one of the best purchases I've ever made automotive or otherwise.
I feehe same exact way. I had ye LCD first then ditched it for the zr-2 gauge. It was difficult go me to era the LCD at a quick glance. The multigauge is so easy to read and also put into any 52mm gauge pod.
I highly recommend thi system. The control box is small, the data logging software is extremely easy to use and read. It makes tuning so simple.
Old Dec 19, 2010 | 10:05 AM
Well the new zt2 allows for up to 3 gauges. You can buy 3 zr-2 multigauges and have various combinations of output( depending on what sensors you have, obviously).
I'm planning on doing this. I want to have boost, afr, and oil pressure.
Hell if you get 3 zr2 gauges and all of the necessary sensors you can have up to 6 different gauges while only taking up the space of 3.
Old Dec 19, 2010 | 06:23 PM
ROCK's Avatar
We have some great gauge mounting solution on this page. The Carbon iber a-pillar set is set for 60mm gauges and made for EVO 8-9s.
See this page.
http://www.roadracemotorsports.com/s...dex&cPath=1_58
ROAD/RACE
