Can't Remove E-Brake Handle
Old Dec 25, 2010 | 05:57 PM
mx4life85's Avatar
I received the Rexpeed CF E-Brake Cover, but I can't seem to get the old one removed. I've twisted every which way, with all my might and it still won't budge.
What's the trick?
Old Dec 25, 2010 | 06:12 PM
CJ2X's Avatar
I've been wondering the same thing.. I've been meaning to get rid of this ricey MR one..
Old Dec 25, 2010 | 08:54 PM
MR Real LA's Avatar
well idk if the MR handle and the GSR handle are the same but mine, a MR, has tiny screws on the sides...use an L key to remove them and the handle should come out effortlessly...but then again, i'm not sure if they're a difference in the handles....lol
Old Dec 25, 2010 | 09:06 PM
Hi Im Vinh's Avatar
I'm curious as well on how to remove it, as well as how the quality of the rexspeed e-brake is
Old Dec 25, 2010 | 09:33 PM
mx4life85's Avatar
The quality looks great much better than that of the OEM peice. Shame I can't get it off though...
Old Dec 25, 2010 | 09:39 PM
heel2toe's Avatar
Assuming you have the stock leather ebrake handle as opposed to the upgraded factory MR piece it can be kinda a pain to get off. My technique was that I grabbed a blowdryer and heated the handle up for a little bit and then just pulled it straight off.
Old Dec 25, 2010 | 10:45 PM
jdmEviL8's Avatar
What's the trick?
on my 03, it took a large pair of channel locks and tons of muscle, but it twists off.
Old Dec 26, 2010 | 05:57 AM
mx4life85's Avatar
Do you think a heat gun would be too much?
Old Dec 26, 2010 | 06:02 AM
Evo8ux2's Avatar
no that'll work fine as well as long as you leave some distance to it so you dont burn the leather
Old Dec 26, 2010 | 06:06 AM
escodotcarter's Avatar
i believe you just pull straight forward, no twisting.......heating it up will help it release.
Old Dec 26, 2010 | 06:11 AM
wizzo 8's Avatar
It pulls off just dont let it go on accident and let it fly into the windshield.
Old Dec 26, 2010 | 08:59 AM
mikeevo21's Avatar
i did mine i just use vice grip pliers to twist it off and avoid further accident lol...u just to have to be a little patient..
Old Dec 26, 2010 | 06:27 PM
k20toEVO's Avatar
same, I used a yellow microfiber towel over it, and vice griped pliers. moved it sideways until it broke loose and it pulled right off.
Old Dec 26, 2010 | 07:57 PM
JGUEVO's Avatar
Just intalled the same thing on my GSR, there were no holes on the stock one just twist them off no tricks at all, I think you just haven't twist it hard enough so it didnt came off(it was really hard to remove it tho), but for the rexpeed one it has 2 small holes at sides.
Old Dec 27, 2010 | 12:17 AM
DormantBeast's Avatar
I cudnt twist mine off so this is wut i did... took my knife and cut down the center of the oem stitching and pulled off the wrap then took my knife and cut the rubber cylinder around the ebrake handle( u can take ur time i did to make sure i didnt scratch the ebrake handle )... time spent pulling on ebrake about 1 hr... time with knife 15 mins
