6 speed to 5 speed
Old Dec 26, 2010 | 01:07 AM
mrevoix2006's Avatar
6 speed to 5 speed
hey this might be a dmb question bt will a 5spd tranny bolt right into a mr? if not what else is needed?
Old Dec 26, 2010 | 03:32 AM
pwrofturbo's Avatar
Yes, it'll bolt on. You'll want the 5 speed shifter assembly as well.
Old Dec 26, 2010 | 03:43 AM
thanks for the info one other question is wold 7s 8s an 9s trannys all work?
Old Dec 26, 2010 | 04:04 AM
raasfaas's Avatar
I'm interested in doing this swap too...and from what I have read yes they should all fit.
Old Dec 26, 2010 | 06:08 AM
goforwand's Avatar
Originally Posted by mrevoix2006
hey this might be a dmb question bt will a 5spd tranny bolt right into a mr? if not what else is needed? an does anyone have one for sale?
You will need the following 5 speed parts- shifter base, shifter cables, shift linkage bracket, tranny side mount, 5 speed sensor harness.
You will also likely need the 5-speed center console, although alot of people continue to run the MR console.
The parts from the dealer are pretty expensive; best to look in the classifieds to see who is parting out a 5-speed Evo.
You can pick up a used tranny for ~$1,000; your 6-speed is basically worthless in the open market unless it is 100% operational.
If you aren't 100% comfortable doing the conversion yourself (it's not that complicated) then contact Baierl Mitsu and ask for Mike as he's really the only trustworthy person in W. PA that I know of. G/L
Old Dec 26, 2010 | 11:40 PM
ok cool thanks alot man do you think all of the stuff needed is included with a transmission? like if i buy one from a junkyard or something
Old Dec 27, 2010 | 12:10 AM
chaotichoax's Avatar
please search before you post
https://www.evolutionm.net/forums/ev...ap-thread.html
closed...
