Not reading full boost...New gauge and same thing
Old Dec 29, 2010 | 09:56 AM
My03evo's Avatar
Arrow Not reading full boost...New gauge and same thing
The car only shows maybe half of what the boost really is. I've searched and read it is something with the boost solenoid under the battery or somewhere? Tried new gauge for the hell of it and same thing. I'm new to ecm controlled wastegates so can someone help me how all this works like a diagram or description how the boost flows out of the turbo through whatever to the wastegate or any comments or tips.
Thanks
Old Dec 29, 2010 | 09:59 AM
RaysEvoX's Avatar
What boost gauge? Is your boost pill in the right spot/line?
Old Dec 29, 2010 | 11:02 AM
warstang27's Avatar
wheres your gauge tapped to? +1 w/RaysEvoX the pill might be gone
Old Dec 29, 2010 | 12:11 PM
Bobster22388's Avatar
Are you sure none of your vacuum lines are kinked or anything like that also?
Old Dec 29, 2010 | 11:36 PM
My03evo's Avatar
Honestly it's not my car....yet
Took a car for a test drive and he told me this situation, I was actually so busy lookin at the wideband and meth gauge I forgot to look at the boost gauge. I'm not sure where the boost line is tapped into nor about the pill that's why I'm trying to learn more about how its setup so I can rule stuff out and I'm just curous on how some things work.
Where is this pill and what does it do?
Old Dec 30, 2010 | 09:54 PM
My03evo's Avatar
Bummpp...anyone? My vote is someone tapped into the wrong spot for the boost line
Old Dec 30, 2010 | 10:17 PM
onewickedninelv's Avatar
+1 ^^^ I had this happen to me when I installed my gauge.
Old Dec 31, 2010 | 09:24 AM
cfdfireman1's Avatar
Question how do you know...
...what the "boost really is"?
Old Dec 31, 2010 | 08:20 PM
good catch Evolution84
Old Dec 31, 2010 | 09:23 PM
LimitedSlip7's Avatar
Yea... check that shaft play and general turbo health symptoms. Even if it was a kinked line it would continue to build guage pressure through a 5/6th gear pull to full boost if it were a flow restriction.
Old Jan 1, 2011 | 01:13 PM
My03evo's Avatar
Because when it got tuned they hooked their own boost gauge and it was reading 35psi (or w/e they set it to) and I forget what it shows now but it was low like 15 and theres no way it has only that low psi cause it pulled like a ****
This is on a car I'm buying and I was on a test drive. I should have the car on monday. If something did happen and the gauge is really reading the "real psi" then I can't imagine what it would be on a high psi
Old Jan 2, 2011 | 07:38 AM
so what you're saying is....
.....you have no idea "what the boost really is"?
Old Jan 2, 2011 | 07:50 AM
EvoJoeIX's Avatar
+1
35psi on a stock turbo is stupid anyway, way out of its efficiency range
Old Jan 3, 2011 | 08:15 AM
My03evo's Avatar
Originally Posted by EvoJoeIX
+1
It's a fully forged shortblock, Buschur stage 3 head, cams, FP Black, injectors, aquamist, full intake and exhaust, mini battery, most of the parts are BR. Bushwacker trans, Exedy triple disc and much more.
Sure fp black is still a stock turbo frame but are you saying 35psi is still too much for a black?
Old Jan 5, 2011 | 07:22 AM
My03evo,
I'm still interested in how you know, "what the boost really is"?
