clutch issue... please help..
wats up guys.. so im having an issue.. today im at a light and my car is in 1st and clutch in.. all of the sudden my clutch pops and stalls my car.. now the pedal was all the way to the floor and wouldnt come back.. i had to manually lift it back.. now i managed to press it an it let me put it in first afta a few shots and while revving a bit without grinding gears.. now i now its not the tob popping off cause i had that issue before andi put in the bracket for insurance.. now i got the car home and wen i looked under the hood the little cylinder that has the little rod that pushes the shift fork was bent.. like bad lol... now i have a compettition stage 4 clutch and its almost 1 and half with it.. could that be the reason y it bent.. or wat.. im confused.. im gona look more into it tomorrow to see if the master cyl. went.. or wats goin on... i didnt see and liquid either.. so wat do u guys think.. im thinking of just down grading my clutch to like a stage 2.. i dont need a stage 4 for my mods.. lol.. especially on a dd.. thanks guys.. any info would help..
this happened to me its your clutch cylinder thats on your trans and also check your fluid level....change your lines or buy a new clutch cylinder thats on your trans directly and check out the one on your firewall too.
good luck bro
good luck bro
Wow can't believe it bent the pin, post up a pic when you get home so others can see what happened. You'll know right away if its not the wedge collar (a.k.a TOB Clip) as the clutch fork will be in the middle normal spot of its throw when you take off the clutch slave cylinder....
FYI I have a clutch fork stop and had the clip pop off anyways, it was explained to me that occasionally this does happen, and it can be the TOB itself not "holding on"...
I hope not.. I already had that issue and taking down the tranny ain't no joke lol.. I'm gona check it today.. I doubt it popped out cause I was still able to change a few gears I just had to press down on the clutch really hard and rev a bit and they slid right in.. ill post sum pics up so u guys can see.. lol..
alright guys so theres the pic of the clutch slave how it bent... now one thing i was looking at is the position of the shift fork.. now isnt suppose to be away from the motor not toward the motor.. the slave isnt even touching it and the fork is in that position... i think the damn tob came out.. aaggggaaiiinnnn.. wat do u guys think..
so i came to my conclusion.. im gonna get the tilton clutch kit, but the one that is the push version.. its like 1700 for it.. but i know i wont have to drop this damn tranny again for one damn stupid clip.. i luv my evo.. but sh*t like this makes me wana part from it.. lol..
