Oil, Battery, and brake lights come on on dash......weird, help
Old Jan 12, 2011 | 11:17 PM
Evolver9's Avatar
So earlier tonight I was finally able to really drive my car for the first time on e85. I was loving the new found power. I hit about 120-125 then all of a sudden my radio shut off, my oil, battery, and handbrake light came on the dash. When I slowed down to a respectable speed the lights went away and my radio came back on. Any ideas as to what could've caused this?
Old Jan 13, 2011 | 12:30 PM
turbotalawd's Avatar
Check your connections and grounds at the alternator and the battery.
Old Jan 13, 2011 | 01:18 PM
Evolver9's Avatar
Everything seems firm and in its place, if something is loose, wouldn't everything still be lighting up?? as soon as i slowed down to about 80 everything went back to normal. I heard a rumor a while ago before i got the evo that if you start going too fast something like this happens as like a safety feature to tell you to slow down pretty much but i have no idea.
Old Jan 13, 2011 | 10:39 PM
uh.....youre kidding right?
Keep checking connectors. Something is loose.
Old Jan 13, 2011 | 10:45 PM
420a-t's Avatar
Something is loose, Or I've had it even happen to where you have an exhaust leak/ something is overheating the alternator causing it to not to do it's job. I know the exhaust is nowhere near the alternator on these cars, but something to look at. I'd also test the alternator and battery too.
Good luck.
Old Jan 14, 2011 | 07:33 PM
IMPdemon's Avatar
Hmm, may be a longshot, but have you looked at your firewall harness connector? Check out this thread for info.
https://www.evolutionm.net/forums/in...s-how-fix.html
strife
85
May 12, 2025 04:08 PM
ALEX9X
Dec 16, 2016 07:14 PM
ALEX9X
Dec 4, 2016 12:19 PM
mitsumaster
Nov 14, 2015 07:55 AM
nmilsaps
Apr 2, 2012 05:31 AM
