How much boost lost TB seals
mil spec shaft seals - $18-$20
another tune - upwards of $300+
Which would you rather pay?
I know you're anxious. I just had my first tune done this past October, and patience is not a virtue of mine, but I made sure there were no boost leaks and the car was locked/cocked/ready to rock beforehand. We are only trying to save you money/time/headaches in the long run.
https://www.evolutionm.net/forums/ev...yone-read.html
Make sure you fix all your boost leaks before you do any type of tuning. It is absolutely pointless to get a tune without fixing them.. as stated above by Chad @ CBRD.
Yes, this can't be stressed enough. Go ahead and tell your tuner that your TB shaft seals are leaking. If he/she tells you that its ok, then your next step is to find another tuner. It's your money, so do what you want. Lemme break it down to you, shotgun style:
Not to mention that it's not really how much boost you lose. It's more about your MAF calculating the amount of air being drawn in. Your ECU then tells your injectors the amount to spray for that calculated air. If you have a leak after the MAF it will throw off your fuel. Your computer is throwing fuel at air that might not really be there because it leaked out. Hope that's not confusing...lol
This is the easiest way to think about it: 1. MAF sees "X" amount of air. 2. leak and only "A" amount of air gets to the cylinder. 3. Injectors added fuel for "X" amount of air, NOT "A" amount. Since it's a leak, its probably not linear or a constant. That means "A" could always change, throwing your tune out of wack.
Another thing to think about. Depending on how many leaks and how bad they are, it can also cause your turbo to work harder just to make up for the leaks.
I could go on and on...lol
Sorry for the ramblings....
there is no way to calculate that...
it will change with temps/pressure, etc...
plain and simple, if you have never replaced them... DO IT, you need them.
EVERY evo we've pressure tested recently has needed them if they werent replaced before!
cheers
cb
cheers
cb
Here it is. Blue run was with the TB seals leaking. On the red run, I had repaired the seals with WORKS high pressure seals and I also switched from the oem 9.8 housing to the 10.5 housing (which in theory could cause a loss in spool up). This graph isn't back to back...they are separated by about a year...but conditions are very similar. Besides, we aren't comparing power, just spool up. I don't think a relatively drastic increase in spool like that can be called idiopathic, whereas power may change from day to day. I am VERY confident that the increase in spool is due to fixing that leak...
They leak from the factory and only get worse. If getting tuned, replace them. The idea of replacing them may sound intimidating, but it is a pretty simple task, especially when following a how-to.
A boost gauge that is bouncing is most likely a faulty gauge or sending unit.
