My car is a shop WOW
Old Jan 24, 2011 | 07:07 AM
5LEEPERISAH23I's Avatar
Originally Posted by AlwaysinBoost
x2
I just found a leaking EGR valve that was causing all kinds of idle/stalling/driveability issues. the car was boosting fine on the road, I was hitting 24psi by 3800 RPM in 3rd gear, but it wouldn't hold any pressure at all when I leak tested it. Once that leak was fixed my car was back to driving like stock.
bottom line is that if you haven't leak tested your car recently chances are you've got a leak.
Yeah hope it is that easy. I'll find out soon. Like I said tho it is not in my hands anymore
Old Jan 25, 2011 | 06:58 PM
UPDATE:
JNZ called me today, they told me pretty much my spark plugs were f*ckkkkeeddddd. Replaced them and it started right up.
They are going to call me sometime to confirm that was the problem.
Im so relieved.
Old Jan 26, 2011 | 05:22 AM
dillon410021's Avatar
try throttle and start, check for leaks, check IAC
Old Jan 26, 2011 | 05:54 AM
M4Lki3r's Avatar
Veteran: Marine Corps
Originally Posted by 5LEEPERISAH23I
UPDATE:
Can I ask how you checked for spark? Your first post said it was getting spark.
To me that means pulling the spark plugs and grounding them while someone cranks it. If I see spark, it's getting spark. If not, check the gap and re-crank.
I would have thought you would notice something like an f'ed up spark plug during this test.
Old Jan 26, 2011 | 06:09 AM
AlwaysinBoost's Avatar
I'm optimistic for you, but I don't think plugs would cause a no-start condition only when it was cold.
Old Jan 26, 2011 | 08:12 AM
When they pulled them they were covered in fuel. When i did it i was getting spark but, maybe that was before they got covered in fuel.
Old Jan 26, 2011 | 08:13 AM
idk that is what they told me, They are replacing them with different plugs today, see if that was the problem or not. They have not called me today yet. So only time tells
Old Jan 26, 2011 | 08:18 AM
05blue8's Avatar
It's possible you could have totally flooded all the cylinders by trying to start it and cranking for so long so many times. You checked compression and it was fine, when you pulled plugs to check compression you didn't notice them being covered in gas or the strong scent? Did you ever scope the cylinders to see if there was anything down in there? If so the scope should have also come out coated in fuel too. I'm not saying their diagnosis is wrong, just saying that seems weird you've had this problem for a few days, have checked compression, never noticed the fuel before, and they found it but you never smelled anything.
Old Jan 26, 2011 | 12:42 PM
i did but thought the next day they would be dry, i guess not . and yea i did notice them being covered in gas.
i saw fuel n smelled it, just did think anything that big of it.
Old Jan 27, 2011 | 07:39 AM
05blue8's Avatar
If you had pulled the plugs it may have evaporated out after a few hours or overnight but putting the plugs back in to seal it up will definitely make it last a while. I'll keep my fingers crossed for you, I've done the same thing. I used a bendable 3 prong grabber device and a shop rag to dry them out mostly then a fan for about 5 minutes in each cylinder and that did the trick for me. Hope it all works out
5speedwtneed
Feb 8, 2024 04:11 AM
XSilverJ
83
Jan 16, 2024 06:37 PM
wazzelby
Mar 29, 2017 06:28 AM
whatever210
Oct 19, 2015 07:18 PM
sprx19
Oct 6, 2013 05:59 PM
